Pocket GPS World :: View topic - Camera Voice Warnings
Makka
PostPosted: Sat Jun 18, 2005 11:14 am    Post subject: Camera Voice Warnings Reply with quote
I have recently downloaded the 5158_data.chk file for the Speed Camera POI warnings.
However, when I try to set a warning distance, then select the "bell" my TTG 300 locks up for about 10 seconds then switches off and back on again.
Am I doing something obviously wrong?
Does the file go in the main folder or the Voices folder?
Does the name of the file remain the same or does it have to be renamed data.chk after renaming the original data.chk file?
I have read the instructions for installing but fin them a bit misleading.
Any help would be most appreciated.
Makka
PostPosted: Sat Jun 18, 2005 11:28 am    Post subject: Reply with quote
BTW, forgot to say that the 5158 file is the correct version for my TTG Exclamation
finntricky
PostPosted: Sat Jun 18, 2005 12:37 pm    Post subject: Reply with quote
all i do is delete the data.chk file from the tomtom card, and replace with the new file, 5158_data.chk, then rename this to data.chk
i should back up the file first, but never do Laughing
rkm_hm
PostPosted: Sat Jun 18, 2005 3:39 pm    Post subject: Re: Camera Voice Warnings Reply with quote
It goes in the Root Directory (Folder) - not in the one with the maps - nor in any other sub-directory for that matter.
The new file must be renamed to data.chk - having first renamed or deleted the old one. Otherwise, you won't have a data.chk file at all - which is probably why it goes ape!
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
Makka
PostPosted: Sat Jun 18, 2005 8:05 pm    Post subject: Reply with quote
I originally did exactly what you both said and that's when I had the problem, however, I've tried again and it now works!!!
The wonders o technology eh!!!?!
Thanks for your help guys. :D
