Pocket GPS World :: View topic - TTN3 and TTN5 on the same PPC
oddsock
PostPosted: Thu Jun 02, 2005 6:55 pm    Post subject: TTN3 and TTN5 on the same PPC Reply with quote
I would like to get TTN5 for it's improvments but would not like to loose some of the features that will be dropped from TTN3 . My question is: If I buy a full copy of TTN5 would I be able to run both aplications on one PPC if they were loaded and run from the storage card.
PostPosted: Thu Jun 02, 2005 7:38 pm    Post subject: Reply with quote
You can do that but you will have to keep independent maps - the versions cannot read the other version's map.
jonmat
PostPosted: Sat Jun 04, 2005 10:13 am    Post subject: Reply with quote
This is very interesting, so is it just a case of installing the TT5 upgrade and it will not overwrite TT3? It would be nice to keep TT3 as well, incase of emergencies!
View user's profile Send private message Yahoo Messenger MSN Messenger
insanity
PostPosted: Sat Jun 04, 2005 10:39 am    Post subject: Reply with quote
No - the upgrade info specifically states that your copy of TT3 will not be valid after you activate TT5.
The original poster was talking about buying the full version of TT5, not the upgrade.
AllenJames
PostPosted: Tue Jun 07, 2005 1:23 pm    Post subject: Reply with quote
I can confirm that you cannot have both versions installed at the same time even with both maps on the SD card.
TT5 just wipes out TT3.
I hope TT get the SDK out soon, I need checkpoint !!!
Garmin Edge 800 (cycling)
Magellan GPS315 (Geocaching)
Tomtom Go (driving)
iPhone 5 (phoning)
PostPosted: Tue Jun 07, 2005 4:53 pm    Post subject: Reply with quote
Only if you install to the same folder.
AllenJames
PostPosted: Tue Jun 07, 2005 5:12 pm    Post subject: Reply with quote
I installed TT5 to the SD card and TT3 to default directory.
Whenever I start them up, TT5 always loads.
Tomtom Go (driving)
iPhone 5 (phoning)
PostPosted: Tue Jun 07, 2005 5:43 pm    Post subject: Reply with quote
Do you have one or two icons? You may want to refresh the shortcut for TTN3 - it may stil show the old icon but point to the TTN5 location.
You can also use the Pocket File explorer to start TTN3 directly.
psneddon
PostPosted: Tue Jun 07, 2005 11:17 pm    Post subject: Reply with quote
You could try installing one version to the SD card and one to storage. Also V5 can (with a very small change) read V4 (map v390) maps. I dont know about the maps that come with version 3.
AllenJames
PostPosted: Wed Jun 08, 2005 8:56 am    Post subject: Reply with quote
I have tried and tried and I just cannot get both installed.
I choose to install TT3 to main memory (default locations)
I choose to install TT5 to SD Card.
It always appears to put TT5 over the top of TT3 even though I asked it not to put it in main memory.
I done a hard reset last night to see if it was just the PDA being daft but it made no difference and now I have to install all my stuff Sad
Arrrrrrrrrrrrrrgh !
Tomtom Go (driving)
iPhone 5 (phoning)
oddsock
PostPosted: Wed Jun 08, 2005 9:47 am    Post subject: Reply with quote
I know the horse has bolted but before I start installing any new aplication I make a backup with"Sprite Backup Premium Edition" then if disaster strikes a restore of all pre installation programs and settings are only a hard reset and a few screen taps away ,although you may be getting a little tight for space on a 256mb card with 2 sets of maps and backup files
Have you tried installing the first version to the storage using the guide on these forums ( I think ,but not sure it requires a reg hack or moving some files ) and then when that working ok installing the second version to main memory ? Dave
outie
PostPosted: Wed Jun 08, 2005 10:09 am    Post subject: Reply with quote
Can you share the information about how to read V4 map with V5? Thanks!
AllenJames
PostPosted: Wed Jun 08, 2005 10:28 am    Post subject: Reply with quote
Does sprite backup backup the whole contents of the PPC to SD card ?
I have an oldish backup (week ago) would that put all my stuff back ?
Tomtom Go (driving)
iPhone 5 (phoning)
oddsock
PostPosted: Wed Jun 08, 2005 2:07 pm    Post subject: Reply with quote
You can cofigure it to save what ever you want! but I don't see much piont in saving "all the ppc" you just save the volatile storage as an EXE file. You can however save "all the ppc to your Pc in case of a complete catastrophe..As for your saved backup ..It depends what you used and how it was saved, as to how easy it is to restore
oddsock
PostPosted: Wed Jun 08, 2005 2:21 pm    Post subject: Reply with quote
continued : but all the information you need to restore should be there.BTW the exe file for my backup is 15.9mb
