PaulBoy Occasional Visitor
Posted: Sat Feb 05, 2005 6:10 pm Post subject: Changing TTN3 GPS Driver Question ? |
I had Memory Map installed on my Ipaq 2210 before buying TTN3 and after the excellent advice here about TTN3 "hijacking" the BT com ports etc when I installed my new TTN3 from scratch I used the CAB file method and installed the GPS Driver 2.07 instead of the newer 3.07
Robert's your mother's brother & all is working well ...
I have a m8 who already has TTN3 installed and now wants to install Memory Map (also on an Ipaq although I don't know which model he has)
Do all Ipaq's have the TTN3 BT issue or was it just the 2210 ?
If my m8 needs to change his GPS from 3.07 to 2.07 what's the procedure ? Is it just a case of downloading the CAB file and running it from his Ipaq or do you have to remove the 3.07 driver first ...
Your assistance is much appreciated ... Paul ;) |
lbendlin Pocket GPS Staff
Posted: Sat Feb 05, 2005 9:05 pm Post subject: |
this issue has nothing to do with iPAQs. Any Pocket PC with a BT connection to the GPS and TTN3 installed will have this problem.
We'll have a detailed guide out soon. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Feb 06, 2005 12:07 am Post subject: |
Thanks Lutz ...
about ... Quote: | If my m8 needs to change his GPS from 3.07 to 2.07 what's the procedure ? Is it just a case of downloading the CAB file and running it from his Ipaq or do you have to remove the 3.07 driver first ... | ... can you (or anyone) assist ?
Paul |
Posted: Sun Feb 06, 2005 12:22 am Post subject: |
lbendlin wrote: | We'll have a detailed guide out soon. |
Posted: Sun Feb 06, 2005 12:18 pm Post subject: |
Lutz ... sorry I wasn't being pedantic but my m8 will take delivery of MMap any day now & I wanted to avoid him screwing up his PDA / BT etc
If it isn't straightforward to replace the GPS Driver when the newer one is in place I will suggest he holds off until your detailed guide is posted ...
Paul |
