Pocket GPS World :: View topic - Pocket Streets and GPS connection error
Gil-ad
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Pocket Streets and GPS connection error Reply with quote
I'm working with the Microsoft MapPoint 2002 and a Garmin eMap GPS
connected to my Notebook and I can track my self with no problems.
Lately I tried to connect my iPAQ 3850 (PPC2002) to my GPS using a
serial cable and tried locate my self on the Pocket Streets 2002
(Release 1 (09.05) (08.0902)).
I already download the GPS add-on form the Microsoft web site, but the
Pocket Streets fail to connect to the GPS. I'm keep getting all the
time the message: "The communications (COM) ports is available, but no
signal is being received…"
This message is weird as I did successfully connected to the GPS using
several other PPC GPS aware software as GPS IDEAS™ PRO 1.2 and hand
map.
Any idea how I can make my Pocket Streets work with my GPS?
TIA
Gil-ad
See my reply to your query under 3rd Party Mapping Software
yin1969
Gil-ad
I had a similar problem.
I had a Garmin 12 GPS with a serial cable ended with
a DB9 Female connector. The end of my Ipaq Cable was also
a DB9 Cable. So I figure that a just need a gender changer between the two...wrong. I had to put a Null Modem Cable/Connector since pin 2 and 3 must be crossed.
Once I did that work correctly.
My Setting:
PocketPC Com1 4800 baud
My GPS
Nmea/Nmea 4800 0183 2.0
Hope it helped
