charliekiller Occasional Visitor
![](modules/Forums/images/avatars/gallery/115.gif)
DavidW Pocket GPS Moderator
Posted: Fri Jan 07, 2005 2:42 pm Post subject: |
If you've got one and don't know what it is, configure TomTom Navigator 3 to "NMEA 0183v2 4800" and "Serial cable on COM1:". That should work - but I can't guarantee it.
You will almost certainly need to turn off incoming beams on an XDA for the serial port to work - that can be done via Start Menu, Settings, Connections tab, Beam - untick the box about incoming beams and press OK.
David |
Pc-Mobile Frequent Visitor
![](https://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Fri Jan 07, 2005 4:21 pm Post subject: |
Select "TomTom Navigator GPS" works with almost all GPS.
I think it is just the same as NMEA 4800. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Fri Jan 07, 2005 5:15 pm Post subject: |
Nearly - but not quite.
"TomTom Navigator GPS" is NMEA at 4800bps, but it sends SiRF configuration commands to the GPS. That's unwise if the GPS isn't SiRF based - it may misinterpret them and do something silly.
"NMEA 0183v2 4800" is NMEA at 4800 bps and sends nothing to the GPS.
David |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sat Jan 08, 2005 2:09 am Post subject: |
Sorry the direct link does not work.
Just go to:
http://www.amazon.co.uk/
then search for : Rikaline 6012 GPS
Regards
PocketGps |
Posted: Sun Jan 09, 2005 8:03 pm Post subject: Thanks |
Thanks everyone. It is indeed a Rikaline 6012. I also found out the major problem on my XDA was answered in your FAQ's regarding the com port. It now works a treat. :D |
