KindredSpirit Occasional Visitor
Posted: Wed Jan 05, 2005 12:00 pm Post subject: A silly question - External wired GPS? |
Does anyone know if there is a unit similar to the "Fortuna clip on BT gps" which can be used with an Axim but is not Bluetooth? I want to use my Axim/wired TomTom Nav3 whilst on foot. |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Wed Jan 05, 2005 12:55 pm Post subject: |
As far as I know there are no wired receivers that can be used on foot, they require a power supply to function. If the power could be taken from your Axim the battery life would be considerably reduced.
Hence why Bluetooth is the preferred option for on-foot navigation. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
MikeB Frequent Visitor
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Wed Jan 05, 2005 12:56 pm Post subject: |
It isnt a silly question really, we seem to be getting that request quite a lot recently.
The best way to avhieve this is to buy a handheld GPS like the Garmin eTrex or even better the Garmin Geko and an interface lead. That way you get the best of both worlds a Stand-alone GPS and the PDA with GPS attached.
This is a combination I will be using in the USA later this week. Mainly because the Garmin Geko can last for 12 hours on a set of batteries and will record my track. The PDA will last for 4-5 hours. Therefore I have the GPS on constantly and then just connect up to the PDA when I need to make a decision or to see where I want to go. _________________ Mike Barrett |
Posted: Wed Jan 05, 2005 8:55 pm Post subject: |
I only ask because as I understand it the Fortuna clip on BT gps has a battery built in to power the receiver and the PDA naturally powers itself. I thought someone might make something similar that would allow me to use a self powered receiver with an Axim via a wire |
DavidW Pocket GPS Moderator
Posted: Wed Jan 05, 2005 11:30 pm Post subject: |
The only self-powered wired GPSes tend to be handheld GPSes, of the sort that Mike mentioned. As Mike said, you can get interface cables to use those with a PDA.
I've not yet come across a displayless battery powered wired GPS.
David |
