Pocket GPS World :: View topic - Please Help
Please Help
chulito
PostPosted: Fri Dec 17, 2004 1:24 am    Post subject: Please Help Reply with quote
I'm quite new to all this and in need of some help. I am using tt3 with POI-Warner, my problem is that I am seeing icons and recieving a warning message of cameras on both sides of the road is there any way of adjusting settings in POI-Warner or anywhere else so that I see and get warnings of cameras only in the direction I am traveling and not of cameras in the opposite dirrection.
Thanks in advance
K3FUS
PostPosted: Fri Dec 17, 2004 9:49 am    Post subject: Reply with quote
Now if I remember correctly, if you open POI Warner up there is an option screen that allows you to set an angle of approach for speed camaras.
I assume if you narrow the angle it will only pick up those you approach.
Unfortuntly I am new to this too so can't be more precise, but there's not many options on POI Warner so you should be able to find it.
chulito
PostPosted: Sat Dec 18, 2004 12:24 am    Post subject: Reply with quote
Thanks for your reply have found the setting you said in POI-Warner mine is set at 45 degrees any ideas on what is the best angle to set this at.
