BERTIE Occasional Visitor
Posted: Fri Dec 17, 2004 3:34 pm Post subject: Red Roads. |
Just been into Nottingham with no route selected and tomtom is showing a number of roads or part lengths of roads coloured red, can anyone help please. Also am thinking of getting a 1GB SD card, which ones are compatible ? |
Sniff Regular Visitor
Joined: Nov 02, 2004 Posts: 123 Location: Munich, Germany
Posted: Fri Dec 17, 2004 4:19 pm Post subject: |
one way streets? |
Posted: Fri Dec 17, 2004 6:50 pm Post subject: |
Not one way streets, |
wildcard Occasional Visitor
Posted: Sat Dec 18, 2004 2:46 pm Post subject: Re: Red Roads. |
BERTIE wrote: | Just been into Nottingham with no route selected and tomtom is showing a number of roads or part lengths of roads coloured red, can anyone help please. Also am thinking of getting a 1GB SD card, which ones are compatible ? |
Do you mean light coloured roads with a red/pink dash down the middle.
I think these are roads marked as not for vehicular through traffic . In practice these are residential side streets which local councils do not want used as commuter rat runs - and TeleAtlas have obliged by not using them . I use one on my normal route to work ! - at the entrance there is a little sign saying either "residents only", "access only" or such like. When navigating Tom Tom won't select the road even although it quicker ,when I detour down it Tom Tom asks me to turn around until I have gone more than half way - it then selects the road as part of the new route - a heavy dashed red line appears now appears.
Geoff |
DavidW Pocket GPS Moderator
Posted: Sat Dec 18, 2004 3:18 pm Post subject: |
That's an interesting theory.
I've seen a lot of small roads marked 'not for navigation' in the Navigator 3 UK maps - in Navigator 3 on the Pocket PC they appear with light pink dashes on them. Mainly these are small residential roads - so you could be right - that it's deliberate anti rat-run. I have my doubts, though - I would have thought anti rat-run would be more likely to be implemented by marking roads a category or two lower than they really are to steer the routing engine away from them whilst not affecting local routes.
I treat every one as a map error irrespective of the cause. In some towns, such as Dunstable, Bedfordshire, I find Navigator giving me illogical routes or just plain nonsense if I happen to have gone down one of these roads to visit someone.
I'm more inclined to believe it's a data conversion glitch - maybe TomTom not mapping a road type correctly when the maps were built. Is West Hill in Dunstable so marked on your Go? If not, it could be a difference between the maps, or it could be that the 'red' roads Bertie was talking about are actually something different and not this issue after all.
Anyway, in the Navigator 3 maps, West Hill is marked as "not for navigation" for about the far half of its length. It's a no through road, even unofficially it leads nowhere else. I'm 99% sure it is adopted by the council, so I don't think it's something to do with unadopted roads.
David |
Posted: Sat Dec 18, 2004 7:36 pm Post subject: |
DavidW wrote: | That's an interesting theory.
David |
Yes , West Hill is marked - the portion between Lowther Road and Mentmore Cresent is marked as a normal side road - white with black edge , the remaining portion - the cul de sac from about # 37 onwards- is white , no border , pink dashes.
I could understand the convention if it applied to no through roads only but Derwent Drive a few yards away ( from #17 to #61 approx ) is similarly marked yet can be driven through ( I assume ) , the portions either end (1 to 15 and beyond 61 are not dashed !).
I think this map coding and/or the average speed loading are deliberately chosen to artificially minimise the use of these roads - I have just keyed in a route from 1 Derwent Drive to 71 - rather than choose a route straight along the Drive it maps a huge detour via Lowther road and Borrowdale Avenue (!)
Geoff |
Posted: Sat Dec 18, 2004 9:06 pm Post subject: |
It's not just me, then!
I don't suppose you know Dunstable; I don't live there any more but I often have reason to go there. Lowther Road is the main road through that area; the speed camera on that road is near a school entrance. The other roads off Lowther Road are pretty much all residential - including Derwent Drive, West Hill, Borrowdale Avenue, Furzen Close and Brierley Close. The "not for navigation" bit in the middle of Borrowdale Avenue on the Navigator 3 maps is particularly weird.
Apart from the school by the speed camera and a church, there is a small parade of shops just off Lowther Road to the north, in between Abbey Mews and Oldhill. Apart from that, it's all residential.
As you say, you get some bizarre routes given because of all the "Not for Navigation" marking - I think the one you found is one of the most bizarre yet! There's some more "Not for Navigation" roads elsewhere in the town, including Aldbanks.
Has anyone spotted anything similar anywhere else?
David |
Posted: Sun Dec 19, 2004 11:07 am Post subject: Red Roads. |
Just to clarify the red roads I am seeing on TT Go. The red colour is lighter and brighter than the one when you have a route planned and there seems no reason at all for them to be coloured. i.e. London Road and Trent Bridge in Nottingham are coloured red for about a mile then return to normal. This is a 4 lane main thoroughfare into Nottingham. Have considered a reset or wiping the card and starting over, help. |
Eldar Pocket GPS Moderator
Posted: Sun Dec 19, 2004 1:00 pm Post subject: |
Have you tried changing the colour scheme? (Preferences->Change map colours) |
Posted: Sun Dec 19, 2004 1:09 pm Post subject: Red Roads. |
Yes - all to no avail, think I'll have to start over, is it possible to wipe the card and reload from the CD? |
Posted: Sun Dec 19, 2004 5:08 pm Post subject: |
Could you tell us the map/firmware versions and your colour scheme? |
Posted: Sun Dec 19, 2004 5:45 pm Post subject: Red Roads. |
Firmware is 4.42. Colour scheme is Belgica. |
Posted: Sun Dec 19, 2004 6:33 pm Post subject: |
Couldn't see it myself, at least using the "Map" view. Perhaps it is different in the "Navigator" view, but I cannot use it since I'm not physically in Nottingham. |
Posted: Sun Dec 19, 2004 11:20 pm Post subject: Red Roads. |
Doesn't show in map view, Happened when travelling with no route selected. Will try tomorrow with routing active. |
Posted: Wed Dec 22, 2004 9:28 pm Post subject: Re: Red Roads. |
BERTIE wrote: | Doesn't show in map view, Happened when travelling with no route selected. Will try tomorrow with routing active. |
Any news? You absolutely sure it's not Brittanica you are using? |
