bil Occasional Visitor
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sun Nov 28, 2004 11:07 pm Post subject: |
Can anyone confirm this from real life experience? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
nej Frequent Visitor
Joined: Jun 16, 2004 Posts: 454 Location: London, Ingerlund
Posted: Mon Nov 29, 2004 2:13 pm Post subject: |
I thought it was SDIO... I've got one at home but it's all sealed up for the wife (xmas present). I can let you know on Dec 25th once she's opened it! |
simonm Occasional Visitor
Posted: Fri Dec 03, 2004 10:41 am Post subject: |
I have a 168, I think its SDIO. I have a wireless lan card in it,and it works well, if thats any indication. |
Posted: Fri Dec 03, 2004 12:51 pm Post subject: |
simonm wrote: | I have a 168, I think its SDIO. I have a wireless lan card in it,and it works well, if thats any indication. |
That shows it DEFINATELY has SDIO. |
Posted: Fri Dec 03, 2004 1:25 pm Post subject: |
Its so cool, I can access the Internet when im on the bog ! |
gripp Regular Visitor
![](modules/Forums/images/avatars/3602328439090bb506e3.jpg)
Posted: Wed Dec 22, 2004 11:57 pm Post subject: |
Simon...or anyone,
I'm thinking of following your example of surfing whilst sh@@@ing!!
If I buy a Sandisk 256 WiFi card for the Mitac 168, can you suggest the simplest PCI card for a Win2k computer that has a basic BT ADSL connection via the "Frog" USB modem. I'm not looking for a wireless LAN, simply a transmitter that will communicate with the Mitac.
Perhaps this is a wireless LAN setup, I'm not sure?
Any advice most welcome. _________________ Nokia E65 & TT Nav6 |
Posted: Thu Dec 23, 2004 1:56 pm Post subject: |
DO you just want to connect MItac to PC ? or to internet aswell ?
If you just want to connect Mitac to PC then you will need a wireless hub, then a network card in your PC that is hardwired to Hub.
There are a ton outthere, Netgear are pretty good.
If you then want to connect to Internet, you can get a wireless ADSL router that will connect your PC and your Mitac to your Broadband connection. Using a hub is the best way to connect to BB IMHO adds more security and gets rid of the nasty green frog !
hope that helps.
Merry Xmas. |
DavidW Pocket GPS Moderator
Posted: Thu Dec 23, 2004 4:35 pm Post subject: |
You are talking about a wireless LAN.
The best thing, for security and ease of setup, is to retire your 'frog' in favour of a wireless ADSL router. Switching your main PC over to a router for its Internet connection will, most likely, give a welcome increase in ADSL and even overall stability. There's many different types available; my favourites are the ZyXEL Prestige range. Take a look at the ZyXEL Prestige 660HW (which may be described as the 660HW-61; that being the precise variant needed in the UK).
Be aware, if you do this, you'll need an Ethernet connection to your PC from the router. Ethernet cards can be picked up very cheaply if the PC doesn't have an Ethernet controller built in.
I'm running a high end ZyXEL setup here - I've got a cheap ZyXEL Prestige 650H-E1 behind a ZyXEL ZyWALL 35 (which is around 400 pounds worth of dual Internet load balancing router with high end firewall, VPN, dial backup and wireless network features).
David |
Posted: Thu Dec 23, 2004 6:12 pm Post subject: |
Many thanks for your advice - I'll cogitate over Christmas and come back with more questions later! _________________ Nokia E65 & TT Nav6 |
Posted: Tue Jan 04, 2005 5:01 pm Post subject: |
I already have an old Kingston KNE30BT network card left over from my very original BT Broadband trial of about 5 years go. As this card is rated at only 10Mbps can I assume it would be wiser to buy a newer, faster card?
Assuming yes, are there any network card recommendations - to go with DavidW's suggestion of Zyxel 660HW router? _________________ Nokia E65 & TT Nav6 |
Posted: Tue Jan 04, 2005 7:42 pm Post subject: |
If your only interest is in something that links to the router, the old card you have is probably more than sufficient. After all, there's no harm in starting out with what you have before replacing it with something more up to date. If you're going to get into networking between computers, I'd change it for a more modern 10/100 PCI card, which are inexpensive.
Gigabit is often not worthwhile for home or small office networks. Part of my network (click here for a picture) is Gigabit, but only because two of my machines have factory fit Gigabit cards, and a 24 port 10/100 plus 2 port 10/100/1000 was a logical size switch to buy.
If you look at that picture, which is a little out of date, the main switch, a Netgear FSM726, is at the bottom. On top of that, the silver and red box is the main router and firewall, a ZyXEL ZyWALL 35. The black box is the ADSL router - in my case a cheap ZyXEL Prestige 650H-E1. The modem on top is connect to the ZyWALL for dial backup in the event of an ADSL outage.
The last time I needed a network card - for a friend's old PC - I picked up a 3Com 3C905B-TX from eBay for £3. The 3C905B-TX and 3C905C-TX are pretty much 'classic' designs. The more modern Intel cards are excellent too (my Dell dual Xeon workstation has an Intel Gigabit card built in to the motherboard).
David |
Posted: Tue Jan 18, 2005 11:34 pm Post subject: |
David,
I realise this that thread is incorrectly named, and in the incorrect forum but I'd just like to ask you for a bit more WiFi advice. (Perhaps it would be better moved to another forum?)
I've looked at the ZyXEL Prestige 650H, but my eye has been caught by BT's own Voyager 2100 which by all accounts is very easy to set up - and would have BT suppport. Pricewise it's about the same as the ZyXEL.
Given that this is all very new to me I'm inclined to go for the easy setup BT option, but would like to know if this is a choice I might later regret.
I've today taken delivery of the SanDisk 256Mb WiFi card (next day delivery from Expansys = excellent service), and am struggling to make sense of how it works. I've run a couple of "sniffing" progs like WiFiFoFum and StreetHawk which picked up a couple of signals in Starbucks, but of course without a subscription I wasn't expecting to connect...it just proves the card works!
This will be a long journey over infamiliar territory for me, so I may well be asking for some more advice later. However, I'm very appreciative of the help you've given me so far.
Best wishes,
Geoff. _________________ Nokia E65 & TT Nav6 |
thdimi Occasional Visitor
Posted: Wed May 18, 2005 10:38 am Post subject: |
I got sdio 56k modem to use it with my mio 168 but I cannot connect to my provider due an "unown reason".Any idea? |
