ajhunt Occasional Visitor
Posted: Tue Jul 27, 2004 1:55 pm Post subject: Ipaq 3760 / Fortuna U2 (Serial) / TomTom Navigator 3 - setup |
Hopefully this should be fairly straightforward. I have just bought the above with no instructions on the configuration of the GPS with TomTom.
Can someone give me a definative answer at to which GPS and on which port I should configure the TomTom GPS Status program to get this working?
Many thanks
Andy |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Tue Jul 27, 2004 2:14 pm Post subject: |
NMEA 4800 on COM1 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Jul 27, 2004 2:17 pm Post subject: |
Thanks - I'll give that a try |
tungstentim Occasional Visitor
Posted: Wed Jul 28, 2004 6:31 pm Post subject: |
I've just got tomtom nav. along with a rikaline 6010 reciever and can't open COM1 any ideas ?
Thanks in advance,
TTim
![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Wed Jul 28, 2004 8:02 pm Post subject: |
What Pocket PC do you have? Any external keyboard connected? _________________ Lutz
Posted: Wed Jul 28, 2004 10:09 pm Post subject: |
your spot on, I'vr just fixed it by removing the hp micro keyboard update thingy. Now it works fine and dandy.
Thank you very much for the reply though.
TTim ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Thu Jul 29, 2004 1:36 pm Post subject: Still not working |
As suggested, I'm using the NMEA driver on com1 and still haven't successfully been connected.
It's been pretty cloudy over the fast few days. It's been suggested this could be the factor - is this true?
I've been trying over periods anything upto a couple of hours. Can I leave the GPS unit powered up but without the PDA on and it will still acquire a lock?
I've confirmed that I have no external keyboard driver loaded and the InfraRed is off.
Any help would be greatly appreciated. |
Posted: Thu Jul 29, 2004 1:48 pm Post subject: |
Maybe your Fortna receiver is set to another baud rate or even to SiRF. Leave the connector setting at COM1, and try the other speeds. _________________ Lutz
Posted: Thu Jul 29, 2004 2:02 pm Post subject: |
How long should I try each one for before trying another and do I have to reset the PDA or program each time? |
Posted: Thu Jul 29, 2004 2:15 pm Post subject: |
Simply set the speed, check the mark, and then switch over to the first tab and see if the black dots are running. If not, keep trying. If yes you are done and should see some grey and then red bars.
No need to reset in between. _________________ Lutz
