Dazp Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_anime_021.jpg)
Posted: Sat Apr 02, 2005 4:26 pm Post subject: Please confirm.. |
Hi, Having just downloaded the latest Safety camera update, I checked in my files/folders to check all was well, how ever can anyone confirm that this is correct..
In the Great-Britain-navigator file I have all the cameras plus a couple of other POI's i required..BUT looking in the Great-Britain-Map file, I noticed that the cameras (ov2+bitmaps) download is also here?
Also, I have a file titled 'PocketGPS-UK-sc' , within the TomTom main folder...again with just the camera downloaded...question is, can I delete all these and just keep the Navigator file updated?? Please confirm, cheers.
Cheers Daz |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sat Apr 02, 2005 7:32 pm Post subject: |
The file titled 'PocketGPS-UK-sc' is from the 'good old days' when there was only 1 safety camera file.
Quote: | In the Great-Britain-navigator file I have all the cameras plus a couple of other POI's i required..BUT looking in the Great-Britain-Map file, I noticed that the cameras (ov2+bitmaps) download is also here? |
Do you have 2 map folders?
Check the date stamp of a file in one folder and compare with the same file in the other. The one with the latest date is the required set.
If you remove the old ones and then can't see them on the map you've got the latest ones in the wrong folder.
If you've got two map folders you can delete one, the one without your poi's. _________________ Richard
Posted: Sat Apr 02, 2005 8:50 pm Post subject: |
Hi Richard,
Yes the two folders I have are 'Great_Britain Navigator Map' which contains all my POI's and camera download only, and then the other folder ..'Great-Britain-Map' contains only two files called 'Great_Britain.mms' and 'Great-Britain_Map.cfg'
Do I need to keep these or are they surplus to requirements? Cheers
Daz |
sgould Frequent Visitor
![](modules/Forums/images/avatars/12745715643c17d95b9699.jpg)
Posted: Sat Apr 02, 2005 9:26 pm Post subject: |
Sounds as if you have deleted some essentials. You need one GB Map folder. It should have this lot in it:
Great_Britain.pna
Great_Britain.mms
CLINE.DAT
POI.DAT
MAPINFO.DAT
CNODE.DAT
CNAME.DAT
Great_Britain.mid
Great-Britain-Map.cfg
FACES.DAT
Plus all the PoIs in the same folder. |
Posted: Sat Apr 02, 2005 10:12 pm Post subject: |
sgould wrote: | Sounds as if you have deleted some essentials. You need one GB Map folder. It should have this lot in it:
Great_Britain.pna
Great_Britain.mms
CLINE.DAT
POI.DAT
MAPINFO.DAT
CNODE.DAT
CNAME.DAT
Great_Britain.mid
FACES.DAT
OK I have re installed all these files back into ONE Great Britain map folder, do I now load all this into my Go It was running ok without them tho...just seems odd. It wont get confused and freeze will it?
Cheers Daz |
Posted: Sat Apr 02, 2005 10:24 pm Post subject: |
This is where I have to be careful. I look inside my GO via an Apple Mac. There is, I believe, some setting on a Windows PC that makes files invisible?
Best wait for a PC man, just to be sure. Even the name of the Map folder may be critical and you could have to name it exactly right with all the hyphens and /or underscores in the right place. |
Posted: Sat Apr 02, 2005 10:47 pm Post subject: |
Dazp wrote: | Yes the two folders I have are 'Great_Britain Navigator Map' which contains all my POI's and camera download only, and then the other folder ..'Great-Britain-Map' contains only two files called 'Great_Britain.mms' and 'Great-Britain_Map.cfg'
Daz |
Yes, you can delete the Great-Britain-Map that contains only 2 files.
Dazp wrote: |
OK I have re installed all these files back into ONE Great Britain map folder, do I now load all this into my Go ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
When you re-installed them they should have gone on the GO!
Quote: | It was running ok without them tho...just seems odd. It wont get confused and freeze will it?
Cheers Daz |
It might not have been fully functional tho. If there is spare space on the card it should not freeze up.[/url] _________________ Richard
Posted: Sun Apr 03, 2005 8:41 am Post subject: |
Oldboy wrote: | When you re-installed them they should have gone on the GO! |
I have re-installed them on my PC only so far, not actually transferred to the GO yet untill I had confirmation but assume its OK to go ahead?
Cheers Daz |
Posted: Sun Apr 03, 2005 11:07 am Post subject: |
Dazp wrote: |
Cheers Daz |
I've never done it that way before, but if you have everything in a folder on your PC, you should be able to just copy the whole folder to SD card.
You would have to delete all that's on the card because there might be duplicates and you could run out of memory. So copy all the poi's you want to save, to the PC first. _________________ Richard
