stoneman Occasional Visitor
Posted: Sat Mar 19, 2005 10:34 pm Post subject: Destinator Shut Down |
I'm running Destinator 3 on my XDA 2 with a tom tom bt gps unit, all great for a while but now i destinate to a location and after 20 mins or so destinator just turns itself off.
Any ideas anyone.
I thought it might be the sd card but have since tried another and i am still experiencing the same problem.
After destinator shuts down if i try to start it up again it just locks up and i have to soft reset.
XDA 2 is rom 1.72
extrom 1.72.181 |
lbendlin Pocket GPS Staff
Posted: Mon Mar 21, 2005 2:23 am Post subject: |
Sounds like your PDA runs out of memory. Try running fewer programs in the background, and try moving some data and programs onto storage card. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Mar 21, 2005 8:44 pm Post subject: |
Thanks i'll try that, but according to my memory allocation i have about 47mb free and when i'm running i only have on the sat nav and the phone function + the bluetooth is switched on, do you think that's enough to block the system.
regards |
Posted: Mon Mar 21, 2005 8:48 pm Post subject: |
no, 47 MB should indeed be plenty. It gets dangerous when it's below 10.
So you'll have to verify the memory allocation while Destinator is running. Maybe your version has a memory leak and that then causes the issue after the 20 minutes you mentioned. _________________ Lutz
Posted: Mon Mar 21, 2005 8:58 pm Post subject: |
Thanks i'll run destinator tommorow and try to analyze the memory.
regards |
Posted: Wed Mar 23, 2005 11:18 pm Post subject: |
Ran Destinator on and off all day tues & weds.
I kept checking the memory and i have about 22mb free which seems to remain constant so that dosent seen to be the problem.
It didn't shut down while testing but i think it's only a matter of time
Have you any other ideas??
regards
Stoneman |
Posted: Thu Mar 31, 2005 10:37 pm Post subject: |
Went to oxford today and destinator shut down on the way up but not on the way back?
I can't explain why but i'm going to reload the software and see if that does anything. |
