Pocket GPS World :: View topic - Problems with GPS Signal and Backup
Fast-Trac
PostPosted: Mon Mar 21, 2005 6:26 pm    Post subject: Problems with GPS Signal and Backup Reply with quote
In the last couple of days the GPS unit has been reading about 200 yards off all the time. It tells you to turn too early and if you tap the map it shows everything about 200 yards off. Has anyone else had this problem.
Also a couple of months ago I had a problem with the SD card. I reformatted and it worked fine. However, each time I have backed up the settings and then tried to restore afterwards it does not restore anything.
Is there any way of checking that it has backed up correctly. Again has anyone else had this problem if so any solutions.
Oldboy
PostPosted: Mon Mar 21, 2005 7:31 pm    Post subject: Reply with quote
Backing up only saves your personal settings, it does not back up the whole SD card.
To do that you have to copy everything on the SD card to a folder on the PC using Windows Explorer.
Oldboy
PostPosted: Mon Mar 21, 2005 7:33 pm    Post subject: Reply with quote
Forgot the first question. I've never experienced that problem so I don't know the answer. Sorry 'Sad'
Fast-Trac
PostPosted: Mon Mar 21, 2005 7:46 pm    Post subject: Reply with quote
Sorry I didn't make it really clear. I was trying to back up my settings and preferences not the card but each time I restore none of my settings go back
22.054 (22 May 24)
