Pocket GPS World :: View topic - Fortuna Bluetooth receiver, Dell Axim, Tom Tom
poochie
PostPosted: Thu Mar 17, 2005 10:55 pm    Post subject: Fortuna Bluetooth receiver, Dell Axim, Tom Tom Reply with quote
Hello Wink
How do I make these three talk? I click on the GPS icon, select SIRF Bluetooth, Bluetooth Serial port Com7,
devices all paired up but still the bluetooth device doesnt talk to Tom Tom?
Am I missing something?
poochie
PostPosted: Thu Mar 17, 2005 11:06 pm    Post subject: Reply with quote
edit:
is there any way i can confirm what port the bluietooth is using"
Arrow
nigelw
PostPosted: Fri Mar 18, 2005 1:12 am    Post subject: Reply with quote
Try using NMEA 9600 or NMEA 38400 rather than SiRF. For the Axim X50 the serial port is COM7:
The check box next to the protocol/port selection boxes must be checked for the port to be opened. Click the box so the tick is there, then switch back to the "Status" tab to see comms. progress. You should see "data" being transfered between the 'dish' and the TomTom PDA.
Which Axim do you have?
poochie
PostPosted: Fri Mar 18, 2005 8:58 am    Post subject: Reply with quote
Thanks for that! I dont have the kit on me but will try it when i get home tonight.
I have the Axim X50v and am using Tom Tom 3.07 with Fortuna Bluetooth receiver.
poochie
PostPosted: Fri Mar 18, 2005 9:23 pm    Post subject: Reply with quote
i tried the above, and nothing. Devices seem to be paired ok, but no data transferrring and no connectivity.
Is there anything else left to check ?
nigelw
PostPosted: Sun Mar 20, 2005 2:17 am    Post subject: Reply with quote
First, if the Axim is docked, remove it from the dock. I find that ActiveSync sometimes interferes with BT comms. Then to be sure that the BT ports aren't blocked in any way do a soft reset.
Open the BT Manager and select Tools->Paired Devices. Do you see "Clip-On BT GPS"?
If that's ok make sure BT is turned on, and the Clip-On is turned on. Then start TomTom GPS. TomTom GPS should ask you to choose a BT device unless you've set it to always use the Clip-On, select Clip-On BT GPS. Does the BT (blue) LED on the Clip-On start flickering? It should do to indicate data transfer.
If you select the GPS tab, what are the settings in the two drop-down boxes? Mine are "NMEA 0183v2 38400" and "Bluetooth Serial Port COM7:". The check box is checked.
22.055 (29 May 24)
