Pocket GPS World :: View topic - Editing Map Colours in TomTom 3?
Garry Platt
PostPosted: Wed Mar 09, 2005 8:50 am    Post subject: Editing Map Colours in TomTom 3? Reply with quote
Question I seem to recall that there was some software available that allowed you to change the colours of roads and areas in the TomTom 3 maps. COuld anyone point me to where I might locate it.
I have done a search of the forum but cannot find any reference.
Thank you for any advice provided
PostPosted: Wed Mar 09, 2005 10:07 am    Post subject: Reply with quote
The TomTom Color Style Editor can be found here Smile
MarkHewitt
PostPosted: Wed Mar 09, 2005 3:59 pm    Post subject: Reply with quote
Is there a skin which most closely resembles the colours you would find on Ordanance Survey (1:50,000) mapping?
All the schemes I've seen have colours which are nothing like the standard Sad
barryd
PostPosted: Wed Mar 09, 2005 9:32 pm    Post subject: Reply with quote
Britannica (one of the built-in options) is pretty close to current OS colours.
Barry Davies
LeighB
PostPosted: Wed Mar 09, 2005 11:47 pm    Post subject: Reply with quote
I had a look but it is all in Dutch, I clicked the UK/USA flag at the top hoping for an English page, but it is still Dutch.
Any suggestions
Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02
DavidW
PostPosted: Thu Mar 10, 2005 9:25 am    Post subject: Reply with quote
Go here, which is the download page in Dutch, then click the USA/UK flag. Does that work?
LeighB
PostPosted: Thu Mar 10, 2005 10:29 am    Post subject: Reply with quote
Hi David,
Thanks,
the link did change to English this time, not sure why it did not before??
Leigh
TomTom Navigator 5
Checkpoint 2.02
Sean16
PostPosted: Thu Mar 10, 2005 12:11 pm    Post subject: Reply with quote
I had the same trouble myself, thanks for the help Dave :D
Sean16
PostPosted: Thu Mar 10, 2005 12:29 pm    Post subject: Reply with quote
Sorry if I seem thick but I'm not to sure on how to use this program, can someone please give me some details.
Thanks Sean
barryd
PostPosted: Thu Mar 10, 2005 8:13 pm    Post subject: Reply with quote
You change the colours in TomTom Navigator by selecting different options in the General tab on the Properties page.
Each colour scheme in the drop-down lists is defined by a text file with the extension .CLR in the \Program Files\Navigator folder on the Pocket PC. You can't change the options listed, but you can edit the .CLR files to change the colours that they display. This is where the editor comes in.
The procedure is typically:
- In TomTom, try out the colour schemes to see what they look like. Choose one that is either very close to what you want so you can tweak it a bit, or one that you dislike and would never use so that you can then run riot with it. Note the name of the one you intend to change
- Exit TomTom
- Identify the corresponding .CLR file (e.g. Britannica colour scheme is called britanna.clr)
- Copy the .CLR file from the Pocket PC to your PC
- Make a backup copy of it somewhere else, just in case you regret your changes later
- Use the Colour Style Editor to open the .CLR file, adjust the colours to your liking, then save the file again with the same name
- Copy the edited .CLR file from the PC back to the Pocket PC, replacing the original file
- Start TomTom. The new colour scheme will load
Hope that helps.
Barry Davies
Sean16
PostPosted: Thu Mar 10, 2005 11:00 pm    Post subject: Reply with quote
Thanks Barry will give it a go.
22.055 (29 May 24)
