Filler Occasional Visitor
Joined: Nov 14, 2004 Posts: 37 Location: Stratford upon avon UK
Posted: Wed Mar 09, 2005 9:25 am Post subject: ipaq 2210 and cf gps |
Posted: Wed Mar 09, 2005 8:12 am Post subject: ipaq 2210 cf cards
does anyone know if there is a CF adaptor, that will allow me to fit the cf gps adaptor so that it sits on the back of the ipaq.
ie a z shape adaptor.
Nigel _________________ Nigel
Blackberry Storm
iphone 3gs
Kenwood 5520bt with garmin built in
TT wired GPS - Rikaline Bluetooth 6030 GPS - CF307 CF card GPS - 512mb sd card - sprite full updated, and tt3 , 3.07. 256mb CF card - Win XP SP2 upgrad |
Darren Frequent Visitor
Posted: Wed Mar 09, 2005 10:11 am Post subject: |
Not that I have heard of, is this because you have something in the SD slot that obstructs it? _________________ Darren Griffin |
Posted: Wed Mar 09, 2005 3:00 pm Post subject: cf card |
no it sticks out of the top, and is ungainly, i often think i'll snap it off
it wont fit in the car "fouls windscreen" so i use my tom tom corded one in the car.
:P :P :P _________________ Nigel
Blackberry Storm
iphone 3gs
DavidW Pocket GPS Moderator
Posted: Wed Mar 09, 2005 3:19 pm Post subject: |
It's arguable, then, that you bought the wrong CompactFlash GPS. The Haicom HI-303 series have an adjustable and foldable top section.
I'd be surprised if you broke your CompactFlash GPS - the cross section allows quite a bit of strength (unlike an SDIO GPS). Even if you could find the sort of gadget you were after, the resulting system would be very unwieldy IMHO.
David |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Fri Mar 11, 2005 11:20 am Post subject: |
Same reason I got rid of my CF GPS, it fouled the windscreen when putting the ipaq in and out of the cradle, and restricted my visibility too.
Not to mention it causing it to crash (the software, not the car ) every 5 minutes. |
Posted: Fri Mar 11, 2005 5:30 pm Post subject: cf gps |
I use the wired serial in the car,
But i also have bluetooth which falls over every 10 minutes, which someone has suggested, is a problem with running everything on the sd card. I should by a 512mb CF card and try the bluetooth again.
I bought the CF for portable use, got it cheap on E-bay. works well just unweildly. maybee buy a new haicom instead.
Thanks for the info though
nigel _________________ Nigel
Blackberry Storm
iphone 3gs
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Sat Mar 12, 2005 1:16 am Post subject: |
I would definitely recommend using compact flash with your 2210. The SDIO drivers on it are said to be troublesome. As I have never used SD cards with it I can't actually confirm this.
What I can confirm is that I have not experienced any problems with Bluetooth nor had a bluetooth dropout using 128, 256 and now 1024 CF cards. Once a BT connection is established it is rock solid. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
