Pocket GPS World :: View topic - NAVMAN V3 POI install
AZ
PostPosted: Mon Mar 07, 2005 1:12 pm    Post subject: NAVMAN V3 POI install Reply with quote
I have followed your instructions to load the Safety caera details onto my HP2210 (Navman v3 software). All has gone well until I try and actually load the information onto my device when I just get an error message "No POI's found in input file" despite the fact that I can clearly see all the locator information just as in your screenshot. Can anyone help?
Alan
Tim Buxton
PostPosted: Mon Mar 07, 2005 2:55 pm    Post subject: Reply with quote
Please post a copy of the first two lines of the file you're trying to upload to your iPAQ, and please use Notepad to copy those two lines. Thanks.
Tim
AZ
PostPosted: Mon Mar 07, 2005 3:17 pm    Post subject: Reply with quote
I have now solved the problem - I had been using Excel to open the .csv file. When I use NOTEPAD, it solves the problem. Thanks for your help - your answer pointed me in the right direction.
Alan :D
Miked
PostPosted: Sun Mar 13, 2005 1:09 am    Post subject: Help!!! also have problem V3 Navman software on Navman630inc Reply with quote
I seem to have the same problem. All done as per info on site. When i save to device i get a defult message ...POI File name to change and " No POI's found in input file"
I have used notepad to edit the extracted files.
Tim Buxton
PostPosted: Sun Mar 13, 2005 10:30 am    Post subject: Reply with quote
Then I'll ask you to post the first two lines of the file you're trying to upload, please.
Tim
Miked
PostPosted: Sun Mar 13, 2005 9:15 pm    Post subject: Reply with quote
Hi . Here goes.
3.6302,51.485,"GATSO:3121"
3.8386,51.3166,"GATSO:3122"
Miked
PostPosted: Sun Mar 13, 2005 11:01 pm    Post subject: Reply with quote
Did you open the CSV file in Excel and Save it ? If so, that's where you've gone wrong.
You need to open it in NOTEPAD. If you've saved this in Excel then you may have corrupted the format of the file and this will cause the POI Not Found message.
Try re-opening the original CSV from the ZIP file in NOTEPAD and saving it as a new name, then delete the top lines and you should be good to go using the Navman POI Importer.
Tim Buxton
PostPosted: Mon Mar 14, 2005 11:24 am    Post subject: Reply with quote
Miked wrote:
Hi . Here goes.
Miked
Well, for the first time, I can't see anything wrong! Could you email me the whole file please, and with your permission I'll email you a file which was accepted by my iPAQ without any problems.
Tim
Miked
PostPosted: Mon Mar 14, 2005 7:37 pm    Post subject: Thank you Reply with quote
I have downloaded the data again and opened it in in Notepad. It now works perfectly thank you very much. Will be in touch if i encounter any other problems with my understanding etc. One more question. Does any one know what the total size of these files are.
Miked
icsys
PostPosted: Tue Mar 15, 2005 1:18 am    Post subject: Reply with quote
When you download each POI file to your device you will get a box that tells you the memory available on the device (free space) and the memory required (the size of the file).
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
