Antman500 Occasional Visitor
Posted: Thu Feb 24, 2005 6:59 pm Post subject: Tungsten E Mini Usb Interface - old serial DB9 |
I want to connect my Tungsten E to my Magellan GPS. The GPS has a DB9 serial output, which works fine when connected to my Laptop computer. Is there a way of converting the signals from my GPS (serial-DB9) output too the USB Mini B connection that the Tungsten E requires. If there is would the Tungsten E work in this configuration? |
lbendlin Pocket GPS Staff
Posted: Thu Feb 24, 2005 7:49 pm Post subject: |
highly unlikely. The Tungsten would need to have a USB host interface, and then you would need to have Palm drivers for the USB>Serial converter cable. I don't think either exist _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Fri Feb 25, 2005 2:38 am Post subject: Re: Tungsten E Mini Usb Interface - old serial DB9 |
Antman500 wrote: | I want to connect my Tungsten E to my Magellan GPS. The GPS has a DB9 serial output, which works fine when connected to my Laptop computer. Is there a way of converting the signals from my GPS (serial-DB9) output too the USB Mini B connection that the Tungsten E requires. If there is would the Tungsten E work in this configuration? |
No.
The only way to connect GPS to Tungsten E is via IR.
But honestly I would not bother.
It is better to use another PDA. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Fri Feb 25, 2005 9:49 am Post subject: |
There is a company called kirrio that has pulled together various components for sat nav with the Tungsten E, one of which is a rebadged TFAC MG30 GPS. The Taiwan Falcon Aerospace Corporation states that the TFAC MG30 has the following interfaces –
DB-9 serial connector (MG-10R, MG-30R, MGL-30R)USB serial connector (MG-10U, MG-30U, MGL-30U)PS2 serial connector (MG-30P, MGL-30P).
This would suggest to me that the output from their GPS is the same as the output from my one, or am I missing some thing obvious?
Thanks for your replies. |
Posted: Fri Feb 25, 2005 1:20 pm Post subject: |
Yes Kirio is the one who makes a GPS package for Tungsten E.
Yes the GPS is a serial GPS, they all are.
What Kirio does is to convert RS232 data into IR so it can be used with Tungsten E.
So the Kirio one is the only choice for Tungsten E. Or you could make yourself an IR converter, of which there was an article somewhere on this site.
Whether it is worth it I have given my opinion. _________________ Pc-Mobile
Posted: Fri Feb 25, 2005 4:46 pm Post subject: |
Thank you all for your replies. Its looking increasing like the Tungsten E is not going to be a viable option for my Sat Nav requirements as I am unsure if using the IR port for the GPS is really a practical solution in a vehicle. I will probable wait for the technology to become less expensive as these things invariably do and purchase a self-contained system like the Tom Tom or something.
Thanks again |
theonlyone Occasional Visitor
Posted: Mon May 23, 2005 10:11 pm Post subject: |
Antman - this may be too late for you, but there is another Tungsten TE solution out there. I bought it recently and it works extremely well. See this thread.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=20127
Pc-Mobile - to the best of my knowledge neither solution is related to the IR link. If I'm wrong - my apologies.
Regards, |
