tracker Occasional Visitor
![](modules/Forums/images/avatars/gallery/Sphere_animated2.gif)
Posted: Tue Feb 15, 2005 2:22 pm Post subject: Switching maps |
Hi All,
From my understanding can use TT3 Navigator Maps on TT Mobile. I have copied the directory to the root of my Stoarge card. On other topics I have read that when your run the application, it will ask which map you want.
I my version this is not happen, any ideas?
![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Tue Feb 15, 2005 3:29 pm Post subject: |
you can try to remove the sd card, run the program, exit the program, then reinsert the card and run the program again ( to initiate a folder scan)
Or you can use the registry editing method to point the program to the right map location. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Feb 15, 2005 4:50 pm Post subject: |
I have tried the removing the SD card, but no luck.
What is the reg path info? |
Posted: Tue Feb 15, 2005 6:22 pm Post subject: |
HKCU\Software\TomTom\TomTom Navigator\Maps _________________ Lutz
Posted: Wed Feb 16, 2005 10:08 am Post subject: |
Which is the best Regedit problem for my mobile C500 |
gstenson Frequent Visitor
![](modules/Forums/images/avatars/67531971542660d7943966.jpg)
Joined: 23/10/2002 09:53:59 Posts: 267 Location: Lincolnshire, UK
Posted: Wed Feb 16, 2005 2:35 pm Post subject: |
Either PHM registry editor (which runs on your c500) or MobileRegistryEditor which runs on your PC. _________________ Audi S4
HTC One M8 & CamerAlert |
Posted: Fri Feb 18, 2005 4:12 pm Post subject: Reg |
I cannot find the follow location,
HKCU\Software\ This is no > TomTom\TomTom Navigator\Maps |
Posted: Fri Feb 18, 2005 4:27 pm Post subject: |
then you have a more serious problem... You will need to reinstall TTN _________________ Lutz
Posted: Mon Feb 21, 2005 2:13 pm Post subject: regedit |
Just to make sure that we are talking about the same application.
Why is the a TT Nav < name in the regedit for TOMTOM mobile.
Has anbody switched maps ? Because all the info on here and google, say that it is possilbe but nobody was tested it. ? |
Posted: Mon Feb 21, 2005 2:59 pm Post subject: |
yes, the registry branch is the same.
I am switching maps routinely, so I can confirm that it works _________________ Lutz
Soegaard Occasional Visitor
Posted: Thu Feb 24, 2005 2:23 pm Post subject: |
When you Lutz Bendlin are saying that you able to switch maps, are you talking about TomTom Mobile?
I am not able to do that either.
I have used PC Suite to load the Map into MMC.
As I can see on other threads for POI, that it is not posssible to load a working new POI using PC Suite, but had to use a program called DeskFileMan. Does the PC Suite cause the problem?
Soegaard
Lutz Bendlin
PocketGPS team
Posted: Thu Feb 24, 2005 3:37 pm Post subject: |
Yes, I am talking TomTom Mobile.
But I have never heard of PC Suite or DeskFileMan. What devices do you have, after all? A Mac and a Nokia? _________________ Lutz
Posted: Thu Feb 24, 2005 4:00 pm Post subject: |
The PC Suite for Nokia 6600 have I used to to load the new map onto mu MMC.
The DeskTopFileManager ( http://www.symbianware.com/product.php?id=dfm&pl=n6600 ) have one in this forum used to solve problems with loading new POI into the Map in MMC. When using PC Suite the POI wupld not work.
I am using my PC with XP-Pro.
Soegaard |
Posted: Thu Feb 24, 2005 5:08 pm Post subject: |
By using DesktopFileManager to load POI`s and Maps into the MMC, I have solved my problems.
DONT USE NOKIA`S PC SUITE FOR NOKIA 6600 TO LOAD FILES INTO THE MMC.
I hope this help alot of people here in this Forum.
Soegaard |
