Pocket GPS World :: View topic - UKPostcode add-on
UKPostcode add-on
Di
PostPosted: Sun Feb 20, 2005 12:41 pm    Post subject: UKPostcode add-on Reply with quote
I have downloaded the UKPostcode files and put the .exe and .dat files in the same "ukpostcode" folder on the SD card exactly as instructed. However, when I try to use the system, I get a message "Installation error - ukpostcode.dat not found in .exe folder". This is then (inevitably) followed by "no matching postcode in database". Can anyone please tell me where I have gone wrong? Thanks for any advice!
PostPosted: Sun Feb 20, 2005 12:53 pm    Post subject: Reply with quote
How are you launching the app? If you browse to the PostCode folder and manually click the .exe does it start? If Yes, then the shortcut you craeted is the problem, you may have copied the .exe instead of creating a shortcut to it.
Di
PostPosted: Sun Feb 20, 2005 4:17 pm    Post subject: UKPostcode add-on Reply with quote
Many thanks for your incredibly rapid response to my query. However, I should have given more background - sorry! I can get the opening screen and enter a postcode OK. It is when I tap on "Show on map" or "Navigate to" that I get the error messages.
gasgasgas
PostPosted: Fri Feb 25, 2005 12:39 am    Post subject: Reply with quote
JUST A COUPLE OF THINGS 1 HAVE YOU COPPIED THE EXE FILE THEN PASTED IT INTO WINDOWS/START MENU/PROGRAMS THEN PASTE SHORTCUT THEN IN THE BUTONS OPTION CHANGE A BUTON TO THE SHORTCUT YOU JUST ADDED 2 START TOM TOM BEFORE STARTING THE APPLICATION HOPE THIS HELPS
Di
PostPosted: Thu Mar 03, 2005 5:18 pm    Post subject: UK POSTCODE ADD-ON Reply with quote
Thanks for the help and advice, but I still cannot get this program to work and I am beginning to suspect the basic installation, notwithstanding the error messages it is giving me.
The zip file contains 2 files, setup.exe and TTNcontrol.ini, which never get near the PPC, based on the instructions I have printed out. Is this correct?
Di
howardr
PostPosted: Fri Mar 04, 2005 12:30 pm    Post subject: Reply with quote
Did you remember to install the Tom Tom control file? see below:
Step Three
Note that if you've already got CheckPOInt installed you don't need to complete this step. CheckPOInt will already have installed the necessary TTN support files. Simply carry on from step four.
Use Windows Explorer to copy the 'TTNControl.arm.cab' file to the 'My Documents' folder on your PPC. Then, using File Explorer on the PPC, locate this .cab file and double tap to install it. The .cab file will self delete following installation.
Di
PostPosted: Fri Mar 04, 2005 12:52 pm    Post subject: UK Postcode add-on Reply with quote
Thanks Howardr - Yes, I did exactly as instructed. Have tried reinstalling the .cab file, but get a message confirming that it is already installed OK. Have also verified the shortcut is OK. Both the ukpostcode files are in the same folder on the SD card. If I run the program from this .exe file in file explorer, I get the opening screen OK, enter the postcode, but get the error messages when I tap "Show on map" or "Navigate to". Why??? Am stuck! And what happens to the setup.exe file?
PostPosted: Fri Mar 04, 2005 1:20 pm    Post subject: Reply with quote
What version of TomTom Navigator do you have?
Di
PostPosted: Tue Mar 08, 2005 4:27 pm    Post subject: UK Postcode add-on Reply with quote
Darren - I'm using TTN 3.03. I have since deleted both files from the SD card and pasted in freshly unzipped copies. Even if I run the program directly from the SD card using File Explorer, I get the same error messages when I enter a valid postcode and then tap "Show on map" or "Navigate to"! Yet both the .exe and .dat files are there in the same folder. Can there be a problem with the SD card itself (Kingston 256MB)? Has anyone else had this problem? Can't find any similar complaints on this forum.
