dmingay Occasional Visitor
Posted: Tue Feb 15, 2005 12:05 am Post subject: No joy |
Hi - have just tried that - the POI is still there (an imaginary "Safety Camera" outside my front door!!)
Maybe I should choose a new home location and the switch back to the original one?
David |
DavidW Pocket GPS Moderator
Posted: Tue Feb 15, 2005 4:44 am Post subject: |
I'm probably not the only one who is unclear to what you're replying. It's better to use the "Post Reply" button on the original topic than to start a new one.
David |
gingernut777 Frequent Visitor
![](modules/Forums/images/avatars/32233146843f2d18c31e6d.jpg)
Joined: Nov 03, 2004 Posts: 251 Location: Earth where else
Posted: Tue Feb 15, 2005 5:50 am Post subject: Re: No joy |
dmingay wrote: | Hi - have just tried that - the POI is still there (an imaginary "Safety Camera" outside my front door!!)
David |
see my post
Here _________________ Using an A to Z
Sextant & Compass |
Posted: Tue Feb 15, 2005 11:38 am Post subject: No joy |
Apologies for that - I clicked the lower post reply and assumed it would automatically put the reply post with the same subject, as you would expect!
That's especially confusing when there's a "New topic" button right next to it.
But perhaps I've missed the correct button to press, or does it require me to copy the Subject field manually (which I have done) in order to place it in the right thread?
Thanks for the link to another explanation - will try it tonight.
D |
Darren Frequent Visitor
Posted: Tue Feb 15, 2005 12:03 pm Post subject: |
You must have selected 'New Topic', if you had selected 'Post Reply' then it would have added your reply to the original topic with the same subject line. _________________ Darren Griffin |
Posted: Tue Feb 15, 2005 12:42 pm Post subject: test reply - Mac OS X + Safari *Please ignore* |
Just seeing if that's the case! |
Posted: Tue Feb 15, 2005 12:50 pm Post subject: |
Well, I think I must have pressed the wrong button - thanks for spotting that.
David |
Posted: Tue Feb 15, 2005 12:56 pm Post subject: |
No problem Now the question is, have you resolved your initial issue? _________________ Darren Griffin |
Posted: Tue Feb 15, 2005 1:10 pm Post subject: |
I've yet to try the latest tip - It looks like it should work though.
I've also designed a quick tweak to your "Reply" button which should help to differentiate it from the "New Topic" button.
Can be viewed here:
http://homepage.mac.com/davidmingay/index.htm
Thanks again
David |
