Pocket GPS World :: View topic - Road speed data
Road speed data
Goto page Previous  1, 2
chrisdhall
PostPosted: Mon Feb 14, 2005 6:11 pm    Post subject: Reply with quote
Thanks for the info
Another question. What are the units of the road speeds in the USERTRIP file? MPH or KM/H? Is there likely to be any difference between the US and Europe versions?
Skippy
PostPosted: Wed Mar 23, 2005 12:41 am    Post subject: Reply with quote
ianhb wrote:
I´m not convinced that CoPilot uses the road speeds to determine the route.
The routing algorithm in CoPilot is seriously broken.
When you choose the "Quickest" route, CoPilot will try and use the motorway if at all possible and ignore other road types. This doesn't necessarily give the Quickest route and can sometimes add a large time and distance to your journey.
Also, the "Shortest" route also ignores many minor road types unless it's absolutely necessary to get to the destination using these roads.
Gone fishing!
PONDEROUS
PostPosted: Sat Apr 09, 2005 12:04 pm    Post subject: Reply with quote
Calculating a shortest distance does not involve a time factor, while of course calculating a quickest route does. Hence, Road Speed adjustments relate to Quickest routing, while Road Type bias adjustments are to do with Shortest routing.
It is essential not to mix up these two concepts. However, it may be that ALK themselves, and indeed the PocketGPS forum team have the concepts mixed. Please see the following thread:
Sticky: CoPilot 5 ETA - Tweaking Road Speeds
Page 2 of 2
22.055 (29 May 24)
