Pocket GPS World :: View topic - TomTom Navigator 3.07 CAB files available for download
jlw
PostPosted: Sat Jan 29, 2005 3:55 pm    Post subject: Reply with quote
marklemac wrote:
My first post, so be gentle with me.
I have a Mio 168 with tomtom v3.02 and have it linked to my Mac (OS X) via PocketMac Pro.
I have downloaded the ARM CAB files and have them on screen, but am not sure where to put them in my Mio directory for them to take effect..
I figure its just a case of bunging them in the correct directory and then reboot the Mio.
Can someone point me in the right direction.
Oh PS, The PocketMac Pro software is excellent.
Thanks,
Mark.
I put mine in the tomtom directory
Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case
PostPosted: Sat Jan 29, 2005 4:35 pm    Post subject: Reply with quote
No, it doesn't matter where you put the CAB files. Once you transferred them to the Pocket PC you find them in Pocket File Explore and tap on them - this will start the installation. After installation the CAB files get deleted automatically. If you don't want that "feature" then make them read-only before you transfer them.
There are a number of registry editors around. I am using the one built into the Resco Explorer suite. Have a look at Handango or other sites.
The keys that needs changing are here:
HKLM\Software\TomTom\TomTom Navigator\Maps
You have two string values that need to be adjusted. One value pointing to the map folder
"California" = "\Storage Card\California-Map"
and the other one defining which map to open
"LastMap" = "California"
Verify that both links point to valid values. (The quotes are only shown to indicate string values, they should not be included)
LeighB
PostPosted: Sat Jan 29, 2005 8:02 pm    Post subject: Reply with quote
I copied mine to the SD Card first, and then copied them to My Documents in main memory and executed them from there, this saved a lot of time when I "accidentally" did a hard reset., and had to execute them again.
Do I gather though that I could have made them read only and still executed them, thus avoiding a second copy?
Leigh
PostPosted: Sat Jan 29, 2005 8:26 pm    Post subject: Reply with quote
yup
mallettron
PostPosted: Thu Feb 03, 2005 2:28 pm    Post subject: Reply with quote
sidtheparrot wrote:
"the voice CAB files from your Tom tom install CD and don’t forget a word doc with your activation code on it!"
There are 3 files for the female english voice on the disk, do I just put the zip file on the sd card or do I need all 3?
Ronnie
PostPosted: Thu Feb 03, 2005 4:46 pm    Post subject: Reply with quote
what three files?
soweezy
PostPosted: Fri Feb 04, 2005 2:20 pm    Post subject: grrrrr Reply with quote
tried following the instructions here but I'm if I can get it to upgrade with the cab files
Mitac 168 + TTN 3.01
I copied the cab files to both the sorage or device but still get the same error "no application installed to open this file"
can someoen please help ?
PostPosted: Fri Feb 04, 2005 2:59 pm    Post subject: Reply with quote
You probably copied the ZIP file over. You need to extract the CAB from the ZIP before you copy it to the Pocket PC.
(we are bandwidth conscious)
soweezy
PostPosted: Fri Feb 04, 2005 3:25 pm    Post subject: Reply with quote
unzipped them and copied all 23 of the cab files over
all the files end in a number .001 .002 etc, is that correct ?
SO
PostPosted: Fri Feb 04, 2005 3:53 pm    Post subject: Reply with quote
oh no! hold your horses...
You need only one CAB file (your language choice, ARM processor). Click the appropriate link on the download page, save to your desktop. Unzip ONCE so that the CAB file lands on you rdesktop. Transfer the CAB file to your Pocket PC and execute it there.
Do NOT unzip the CAB file AGAIN!
soweezy
PostPosted: Fri Feb 04, 2005 6:34 pm    Post subject: Reply with quote
got it... duh me (c;
SO
Etwell
PostPosted: Sun Feb 06, 2005 6:01 am    Post subject: Reply with quote
What are the other two CAB file please.
Thanks.
PostPosted: Sun Feb 06, 2005 7:39 am    Post subject: Reply with quote
Those are for Pocket PCs or Handheld PCs with different processors. Back in the Pocket PC 2000 days there were also Pocket PCs with non-ARM processors available, namely Cassiopeias and Jornadas.
Since Pocket PC 2002 only ARM processors are supported (for whatever reason) so it's a safe bet that your PocketPC has one, too.
Jon49
PostPosted: Tue Feb 15, 2005 4:37 pm    Post subject: Reply with quote
lbendlin wrote:
The TomTom Navigator Update 3.07 that is available on the TomTom site forces install not only of the Navigator but also of the TomTom GPS 3.07 .
We do not recommend installation of GPS 3.07 - we recommend 2.07 instead. This gives much less issues when you want to use your Pocket PC with other GPS applications and you use a BlueTooth receiver. (Certain TomTom GPS versions are blocking access tot he BT Receiver for other programs)
I've installed 3.07 TTN and 3.07 GPS on my ipaq 4150 before I read this. The box came with 3.03.
Can I now revert to GPS 2.07 [or 3.03] by using the cab file or do I need to uninstall the lot and start again? Is that easy, I'm still new to this world but learning fast thanks to all the great info here
Jon
PostPosted: Tue Feb 15, 2005 6:24 pm    Post subject: Reply with quote
The article is only relevant for people that want to use multiple GPS programs. If you ever only will use TomTom then there is no need for you to change anything.
Page 2 of 4
