Pocket GPS World :: View topic - Is D3 compatible with Windows Mobile 2003 SE ????
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
Samali
PostPosted: Fri Sep 10, 2004 7:42 pm    Post subject: Is D3 compatible with Windows Mobile 2003 SE ???? Reply with quote
Hello,
I changed my Ipaq HP2210 to Loox720. I can't install any more my Destinator 3, which worked fine on Ipaq. It says not recognised processor.
So ist realy compatible with Windows Mobile 2003 SE ?.
Any idea !!!
thanks
lbendlin
PostPosted: Fri Sep 10, 2004 11:22 pm    Post subject: Reply with quote
Who says that, the Pocket PC or the PC?
Lutz
TomTom/TeleAtlas NAVTEQ
Samali
PostPosted: Sat Sep 11, 2004 6:53 am    Post subject: Reply with quote
The installation procedure starts normally, and when I choose Software installation, I get the following message on the PC: "Processor type unrecognised. 2577 or OS (3421)"
PostPosted: Sat Sep 11, 2004 8:45 am    Post subject: Reply with quote
What version of ActiveSync are you running ? Is it 3.71 ? If so, downgrade to 3.6 and you hopefully will be fine. AFAIK the processor types haven't changed in SE, but I don't have SE here to test it with.
Also if you are running a software firewall on your PC, you may want to temporarily disconnect yourself from the internet and any local network and then temporarily disable the firewall just in case this is having a problem as the firewall can block communication to the ActiveSync Port.
Samali
PostPosted: Tue Sep 14, 2004 7:56 am    Post subject: Reply with quote
Hi Dave,
I tried both doungraded the Activesync, and desabled the firewall, and the result remains unfortunatlly the same as above.
Which surprises me is I didn't have any installation prob. with my old HP2210.
Anyway, many thanks for your reply.
By the way, I have encountered almost the same prob. with GPSAssist, after installation, it wouldn't work. I have a message erreor. That too worked fine on my old PDA. Any idea?
mAfqA
PostPosted: Sun Oct 10, 2004 12:40 pm    Post subject: Reply with quote
Hi!
I experience exactly the same problem as Samali here when I try to install D3 on my new Ipaq HX4700 (running AS 3.7.1)
The installation software on computer says:
If anyone got it to work pls tell us Smile
Incognito
PostPosted: Sat Jan 29, 2005 4:30 pm    Post subject: Reply with quote
http://download.destinator1.com/PocketPC2003SE_patch.zip
Lycean
PostPosted: Sun Jan 30, 2005 9:16 am    Post subject: Reply with quote
You can also fix the problem by making a one line change to destinator's default.ini file (in DestinatorApps\Australia\ConsAU for the Australian version, for example). Here are links to two posts which discuss the change:
http://www.buygpsnow.com/forum/default.aspx?g=posts&m=277
http://www.aximsite.com/boards/archive/index.php/t-41209.html
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
