Pocket GPS World :: View topic - Could the Tsunami cause this???
Goto page 1, 2, 3  Next
buckman
PostPosted: Tue Jan 25, 2005 10:31 am    Post subject: Could the Tsunami cause this??? Reply with quote
Just read an Article that because the Tsunami caused the Earth to move on its Axis , that some/most Satellite Navigation products can be thrown off course slighty??
Is this true?? As from the start of the year (maybe coincidence) my TomTom Go seems slightly sluggish and got its self lost the other day!! which is out of charachter?
Is this coincidence? or is there something in it??
buckman
PostPosted: Tue Jan 25, 2005 10:33 am    Post subject: Reply with quote
Although i should point out that this was a massive disaster and i suppose i or we shouldnt be worrying if our Satnav is a little "out"
Just read it back and i hope people didnt think i was being selfish or dis-respectful, as these people have lost everything... Crying or Very sad
gingernut777
PostPosted: Tue Jan 25, 2005 10:58 am    Post subject: Re: Could the Tsunami cause this??? Reply with quote
I wouldn't worry about it.
The world as a way of sorting itself out, with or without "The Experts"
Look what happened when Krakatoa blew itself apart. Distruction yes, but the world is still going strong.
As for GPS positioning,, I'm still shown exactly in the same position as before.
Using an A to Z
Sextant & Compass
nej
PostPosted: Tue Jan 25, 2005 11:47 am    Post subject: Reply with quote
Technically yes, although it's something like 1 micro-milli-trilli second out over a thousand years or something.
gingernut777
PostPosted: Tue Jan 25, 2005 12:45 pm    Post subject: Reply with quote
better re-set my watch then!
Rolling Eyes
Using an A to Z
Sextant & Compass
Sniff
PostPosted: Tue Jan 25, 2005 2:14 pm    Post subject: Re: Could the Tsunami cause this??? Reply with quote
Actually the cause is more likely to be the earthquake (which caused the tsunami), rather than the tsunami itself. Sounds feasible, but microscopic distances hardly worth worrying about
fitshase
PostPosted: Tue Jan 25, 2005 7:39 pm    Post subject: Reply with quote
Yes, it's true, the earth moved by about 2cm. However, the TTGO is only accurate to 10m so I don't think 2cm will make much difference.
Fitshase
Dazp
PostPosted: Tue Jan 25, 2005 8:45 pm    Post subject: Reply with quote
Surely it makes no odds anyway, as the TTgo is picking up signals from several satallites that are orbiting the earth... as long as they are orbiting and sending signals they will give you your position as before.. whether the earth has moved or not... Confused thats how I tho't it worked any way..!
PostPosted: Tue Jan 25, 2005 9:39 pm    Post subject: Reply with quote
Over in Europe it may only be a shift of 2 cm but in the desaster area some islands have been moved around by 30 meters. Especially for marine navigation this does already have some impact, and as far as I know they started redrawing the maps.
Sniff
PostPosted: Wed Jan 26, 2005 9:38 am    Post subject: Reply with quote
I assume they are receiving satellite signals and using an algorithm to relate those signals to a fixed earth position. If the earth has actually moved 2cm one way, that algorithm will now not be accurate, it'll be 2cm out.
calypso
PostPosted: Wed Jan 26, 2005 10:37 am    Post subject: Reply with quote
Oooh! Your're right.
I was wondering why Jane said "You have almost reached your destination yesterday.
Clever sausage! :D
JOHN
PostPosted: Wed Jan 26, 2005 11:36 am    Post subject: Reply with quote
Surely the satellite positions are calculated from ground stations. In which case there should be no variation in position - in theory!!
R
Sniff
PostPosted: Wed Jan 26, 2005 11:54 am    Post subject: Reply with quote
R
The satellites are in geostationary orbit...ie they are in fixed positions and their location as seen from Earth does not vary. That's how GPS works... The unit times how long a signal takes to reach you from a known satellite position, and uses that to calculate exactly how far from that satellite it currently is. Assuming you can get a signal from three or more satellites you can use triangulation to calculate your actual physical position on the planet (give or take the allowable discrepancies in the GPS system)
nej
PostPosted: Wed Jan 26, 2005 1:04 pm    Post subject: Reply with quote
I didn't think they were geostationary - that's why your receiver has to download the orbital and ephemeris information.
PostPosted: Wed Jan 26, 2005 1:40 pm    Post subject: Reply with quote
If you go to the FAQ page and select 'Basic GPS Theory' then select 'How does GPS work' the answer given suggests that the satellites know their positions and can then pass that information on.
I might have read it wrong - I stand to be corrected.
Page 1 of 3
