Pocket GPS World :: View topic - how do you stick the antenna to a windscreen
telc2
PostPosted: Fri Jan 21, 2005 2:43 pm    Post subject: how do you stick the antenna to a windscreen Reply with quote
hi
ive just brought the external antenna but i dont know how to stick it to the windscreen hope someone can help.
pilot
PostPosted: Fri Jan 21, 2005 3:57 pm    Post subject: Re: how do you stick the antenna to a windscreen Reply with quote
telc2 wrote:
hi
Just done this in my Renault with some white double sided sticky tape - I bought it from a local electrical shop. It sticks well and the aerial is pulling in 9/10 saltellite everytime now.
If you have trouble getting some PM me your address and I'll send you a strip of it.
PostPosted: Fri Jan 21, 2005 3:59 pm    Post subject: Reply with quote
Why stick it to the windcsreen at all? You should be able to get it working by placing it on the dash in the bottom right or left corner of the windscreen.
pilot
PostPosted: Fri Jan 21, 2005 9:24 pm    Post subject: Reply with quote
....... as it stops it moving about on sharp right/left hand bends !!!
PostPosted: Fri Jan 21, 2005 10:01 pm    Post subject: Reply with quote
A blob of bluetack will solve that!
gingernut777
PostPosted: Sat Jan 22, 2005 7:20 am    Post subject: Re: how do you stick the antenna to a windscreen Reply with quote
telc2 wrote:
hi
Stick it on the roof, That where i stuck my External Antenna
Using an A to Z
Sextant & Compass
g0sbv
PostPosted: Sat Jan 22, 2005 8:24 am    Post subject: Reply with quote
Just wondered if you guys dont relise that external antennas have a magnetic base...er um I wonder why that is..maybe to stick on the roof of your vehicle...!! Twisted Evil
gingernut777
PostPosted: Sat Jan 22, 2005 8:35 am    Post subject: Reply with quote
Good minds think alike g0sbv
Maybe that's why their called
External
Using an A to Z
Sextant & Compass
PostPosted: Sat Jan 22, 2005 8:40 am    Post subject: Reply with quote
There can be many reasons why some owners prefer not to mount the accessory external antenna externally, theft and criminal damage are two.
gingernut777
PostPosted: Sat Jan 22, 2005 8:47 am    Post subject: Reply with quote
Then put them back inside the car when not in use, or parked up.
Even when it's fitted with cables hidden under door strips or roof lining, there's always enough cable to bring it back inside car, as i've already done
Using an A to Z
Sextant & Compass
pilot
PostPosted: Sat Jan 22, 2005 9:17 pm    Post subject: Re: how do you stick the antenna to a windscreen Reply with quote
gingernut777 wrote:
telc2 wrote:
hi
Did that with the first one - then water got in and I had to send it back to TomTom for replacement. Now it sits on the black dotted area at the top of the windscreen (no water damage here I hope) - it gets 9/10 satellites - will not be nicked in a car-park (as you can bet that the time I forget to put it away is the time it gets nicked) and the cable run is much shorter. All in all one happy TTG user with an External(well internal if you want to be fussy) aerial !
pilot
PostPosted: Sat Jan 22, 2005 9:18 pm    Post subject: Reply with quote
Death comes when your numbers called.
So what happens when your FLYING and the PILOTS number is called.
Hope there is a co-pilot who can land the plane ??
