look2 Occasional Visitor
Posted: Wed Jan 19, 2005 7:26 pm Post subject: Tomtom with bluetooth config |
Hi !
This might be a dumb question but I have to ask. I can't fins out the right settings for tomtom to comunicate with my BT GPS reciver. It's a reciver called roadnav rn-600.
When I connect my Ipaq to the reciver with BT I found a device called "SPP slave" I bound my ipaq with it and both the ipaq and reciver indicates there is a bluetooth connection. And there is now my problem starts. The reciver indicates it's have contact with one or more GPS sattelites. BUT.... when I start tomtom he says that that he can't determine a correct GPS location.
I have no idé how to setup the gps in tomtom, I think I have tried all the possible combinations. If I look at the tech spec of my reciver it has support for nmea 0183 with 3800 baud.
When looking in the settings in tomtom I can use alot of different nmea 0183 connections. I have tried: nmea 0183v2 bluetooth with "serial cabel on BT" bluetooth serial port com6, 7 and 8.
I have tried nmea 0183v2 38400 with the same "ports"
The reciver shuld also have support for SIRF, I have tried that to.
What am I doing wrong? what settings huld I use? Can't I use my reciver with tomtom? is there something wong with the install so I have to reinstall tomtom?
//Oscar |
lbendlin Pocket GPS Staff
Posted: Wed Jan 19, 2005 8:01 pm Post subject: |
TomTom displays "GPS position unreliable" when you are not close to a street that the map knows. Nothing to worry here.
For the GPS setup, use the simplest possible settings. Verify the Outgoing Serial Port in your Bluetooth settings, then use this port together with "Standard NMEA 38400"
Do not attempt to use SiRF. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Jan 19, 2005 8:06 pm Post subject: |
The problem is that I have no idéa what com port to use. Is there any way I can see that tomtom have contact with the GPS? When starting the gps configyring there is nothing on the first screen, no cordinates att all |
Posted: Wed Jan 19, 2005 8:27 pm Post subject: |
lbendlin wrote: | Verify the Outgoing Serial Port in your Bluetooth settings |
Go to the Bluetooth settings
Start > Settings > Connections > BlueTooth
Tap on Services > Serial Port
Make sure the service is enabled, and NO authentication is required.
Tap on Advanced
Note the Outgoing COM Port. That's the one you must use.
let us know what's written there. _________________ Lutz
Posted: Wed Jan 19, 2005 8:43 pm Post subject: |
Start -> settings -> connections... ?
The only Thing I can find there is:
Avanto connect, Beam, Connections and network adapters.... |
Posted: Wed Jan 19, 2005 8:56 pm Post subject: |
What Pocket PC? Are you using an external BT adapter? _________________ Lutz
Posted: Wed Jan 19, 2005 8:57 pm Post subject: |
Yes, I'm using an external GPS called roadnav cn-600 on a Ipaq 3970 |
Posted: Wed Jan 19, 2005 9:02 pm Post subject: |
Sounds like you run the 3970 on Pocket PC 2002.
In the Today screen, tap the Bluetooth icon in the bottom right corner, and then take it from there. The menu may be a bit different but the idae is the same. Search for "Settings for all devices" _________________ Lutz
Posted: Wed Jan 19, 2005 9:19 pm Post subject: |
I solved the problem !!!!! I was "hacking" some in the registry and found out that the gps was comunication on port 10. I changed it to 8 and made the same change in tomtom and it's working fine now. But thank you for taking your time trying to help me.
But I found another problem. With maps. When I have the "navigate to meny" and the map is kind of detailed, everything works fine. But when I choose map I canät se anything, it just a light blue screen. Any Idéas ? |
Posted: Wed Jan 19, 2005 9:26 pm Post subject: |
in the preferences, check the box "Always keep GPS position on screen" - ths will repaint the map with your current position in the center.
If you live in Corpus Christi, Texas, then you are out of luck. The map there has exactly the problem you describe... _________________ Lutz
Posted: Wed Jan 19, 2005 9:29 pm Post subject: |
I live in Sweden so I'm a bit from Texas. But I'll try that. Iäm reinstallling tha map pack right now.
Thanks again for all your help |
Posted: Wed Jan 19, 2005 9:33 pm Post subject: |
Please update your signature with your location - makes it easier to help _________________ Lutz
