Pocket GPS World :: View topic - Help please !
Help please !
Mike33
PostPosted: Tue Jan 18, 2005 8:59 pm    Post subject: Help please ! Reply with quote
Using TTN3 and i am not sure what i have done but the indicators have dissapeared from the navigation screen.
The indicators i was using are ARRIVAL TIME,DISTANCE TO DESTINATION,TIME TO DESTINATION.
I guessi need to go to properties and advanced menu but if somebody could help me from there i would appreciate it
Mike
lbendlin
PostPosted: Wed Jan 19, 2005 4:08 am    Post subject: Reply with quote
You are almost there. Scroll down to the "Indicators" section.
Note: these will only work if you actually have a route planned.
Lutz
TomTom/TeleAtlas NAVTEQ
Mike33
PostPosted: Wed Jan 19, 2005 10:48 am    Post subject: Reply with quote
Lutz,
Thanks very much for your reply unfortunatly that didn't solve my problem.
I have been into TTN3/properties/advanced/indicators and see that they are set correctly.Then i go back to the main navigation screen plan a route and all that is displayed is the map,direction arrow,speed of the vehicle,Yards to next turn and the satelite guage.Iused to see the 3 indicators to the right of this panel and also i used to have a summary at the start of the screen with the details of the route time/length etc.
Any other ideas would be much appreciated.
Mike
barryd
PostPosted: Wed Jan 19, 2005 12:09 pm    Post subject: Reply with quote
Mike33 wrote:
... I used to see the 3 indicators to the right of this panel and also i used to have a summary at the start of the screen with the details of the route time/length etc.
Hi Mike
You can turn the summary on/off with another of the settings in the Properties - Advanced tab. Look in the Navigator view section for the option Show summary after planning.
As for your main problem, you will only see the three values when you have a route planned (as Lutz said) and you have a good satellite fix. Are you still not seeing them when that is the case?
I also vaguely remember seeing that the Traffic add-on affects where on screen things some things are displayed - maybe someone who uses Traffic can advise if that might be the issue.
Barry Davies
SteveW
PostPosted: Wed Jan 19, 2005 3:45 pm    Post subject: Reply with quote
With TT Traffic the "Show route Scheme" option which appears on the left of the screen does not allow sufficient space so the three boxes above are not shown. "Hide Route Scheme" and the boxes appear.
HTH,
Steve
Mike33
PostPosted: Wed Jan 19, 2005 8:48 pm    Post subject: Reply with quote
Hi Barry,
Thanks for your reply.
Yes it is still the case that i am not seeing the indicators once a route has been planned and i have a good satelite fix.
Regards
Mike
PostPosted: Wed Jan 19, 2005 8:55 pm    Post subject: Reply with quote
Do you have the traffic plug-in installed?
Mike33
PostPosted: Wed Jan 19, 2005 10:18 pm    Post subject: Reply with quote
Yes i do have the traffic [lug in installed and i guess that i lost the indicators around the same time as installing traffic
Mike
Mike33
PostPosted: Wed Jan 19, 2005 10:35 pm    Post subject: Reply with quote
Hi Resolved the issue by looking at a previous members thread Thanks very much all at POCKET GPS for your help.
Best wishes
Mike
PostPosted: Wed Jan 19, 2005 10:36 pm    Post subject: Reply with quote
The answer had already been supplied in this thread but you may have missed it.
With Traffic Installed you have an additional feature to the left of the display running top to bottom. This shows traffic 'situations' on your planned route. The additional screen space this occupies means that with this view enabled the additional info is left off.
It's a simple fix, in Navigator mode, tape the screen and IIRC on the first page you will see the optin to enable/disable 'Show Route Scheme'. Disabling it will restore the information you miss Smile
