Pocket GPS World :: View topic - Connecting Magellan to IPAQ using serial cable
Nuutti
PostPosted: Mon Jan 17, 2005 10:08 pm    Post subject: Connecting Magellan to IPAQ using serial cable Reply with quote
I try to explain my problem with my imperfect english skills..
I'm trying to connect my Magellan Meridian to iPAQ h2110 using serial cable.
I have a cable for Magellan that converts its own port to "female" serial port.
Accordingly I have a cable for PDA that converts its own port to "female" serial port.
I used a gerder changer adapter that has spike connectors on both sides to connect these two female ports. But my PDA isn't receiving any information from GPS.
The adapter looks like this:
The other side:
\ooooo/
-\oooo/
And the other:
-/oooo\
/ooooo\
I don't have a voltage meter to verify it, but I guess upper row pins are connected to lower row pins on the other side. If so pin 1 should be connected to pin 1 etc.. Any ideas what could be wrong at my setup? All the cables work when used separately and GPS works fine with laptop.
PostPosted: Mon Jan 17, 2005 10:49 pm    Post subject: Reply with quote
You need a null modem gender changer (where all the lines are crossed)
Nuutti
PostPosted: Tue Jan 18, 2005 10:10 pm    Post subject: Reply with quote
I still can't get it working..
Before solding an adapter, I tried connecting ports with pieces of wires.
Now PDA recognizes at least some signal, but it says "No NMEA type signal".
GPS manual says:
PIN2: transmit
PIN3: receive
PIN5: ground
In the picture connections are surely wrong, but i tried with no luck connecting
GPS pin2 to PDA pin3 and
GPS pin3 to PDA pin2
as some picture on the net suggested.
PostPosted: Tue Jan 18, 2005 10:37 pm    Post subject: Reply with quote
Have you set the Magellan to output NMEA protocol?
You can verify that by connecting the Magellan to a Notebook and looking at the data in a terminal program.
The wires (2,3,GND) should be ok.
Nuutti
PostPosted: Tue Jan 18, 2005 11:20 pm    Post subject: Reply with quote
Yes it is outputting NMEA, and it works fine with same programs PC version.
Is the GND wire necessary to attach, if I try different connections with transmit & receive wires?
PostPosted: Tue Jan 18, 2005 11:23 pm    Post subject: Reply with quote
Yes, GND is absolutely required.
How about the Baud rate? Have you set it to the same value as on the PC?
Nuutti
PostPosted: Tue Jan 18, 2005 11:32 pm    Post subject: Reply with quote
Baud rates match, but i quess GND was the reason. I was too lazy to attach it when I tried different connections. Rolling Eyes
I quess the right setup is:
GPS pin2 -> PDA pin3
GPS pin3 -> PDA pin2
GND from GPS pin5 to PDA pin5 (across)
I'll try tomorrow if it works. Thanks for the help!
Pc-Mobile
PostPosted: Wed Jan 19, 2005 2:58 am    Post subject: Reply with quote
This is correct.
But it is completely wrong in the picture (5>1, 3>3, 2>4) and that is why it does not work.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.055 (29 May 24)
