Pocket GPS World :: View topic - Help with Smart ST 3 needed
bazzaNW
PostPosted: Sun Jan 16, 2005 3:55 am    Post subject: Help with Smart ST 3 needed Reply with quote
Hi, new here and just bought a Navman Pin300 with SmartSt3. Playing about locally, as we all do I suspect, to test it, I am getting a few problems.
When I first get a position ref it comes up on the map with the name of my street and shows where I am.
If I try to input my address into it, say starting from somewhere else and wanting my address as the destination, it wont find it in the database.
Surely it must be there for it to come up on screen when I am sat outside my house.
I live in Denton Manchester and it doesn't even list Denton, it shows about 5 Denton's spread over UK but not the one in Manchester.
Is postcodes the only way to use this properly, has anyone else had the same problems?
Tim Buxton
PostPosted: Sun Jan 16, 2005 3:01 pm    Post subject: Re: Help with Smart ST 3 needed Reply with quote
Hi bazzaNW, and Welcome
Unfortunately the address lookup is influenced by the way that TeleAtlas supply the data. Often the name can only be found by putting the name of the council area into the 'Area' field. Looking on my version, I'd try putting 'Tameside, England' into the 'Area' field. If this isn't the right area, tap and hold your road and a menu will appear with the name of the road at the top. Tap this roadname and an Address menu will appear - use the topmost word as the 'Area' data and you'll probably get better search results. Not ideal I know, but apparently Navman are working on getting the search engine to perform more logically, as Tomtom did some time ago with TT3.
Tim
bazzaNW
PostPosted: Sun Jan 16, 2005 5:04 pm    Post subject: Thanks for that Reply with quote
Thanks for the info, but it still doesn't work putting Tameside as the area.
No matter what I try it will not find my street name.
Whilst I'm here I noticed a gatso camera that is missing from the list here in Denton. Do I just take a note of the long/lat reading and add it to the list.?
Tim Buxton
PostPosted: Sun Jan 16, 2005 5:18 pm    Post subject: Reply with quote
OK then, can you tell me your streetname, or one a couple of streets away if you're shy.
Send camera details to cameras@pocketgpsworld.com
Tim
bazzaNW
PostPosted: Sun Jan 16, 2005 5:43 pm    Post subject: street name Reply with quote
Hi Tim,
west park avenue, haughton green, denton, m34 7tg
Tim Buxton
PostPosted: Sun Jan 16, 2005 5:58 pm    Post subject: Reply with quote
OK, this is another quirk of the search engine; I'm not sure if this fault is attributable to TeleAtlas or Navman. Anyway, where a road starts with East, West, North or South (and there may be other instances) then to search for the road, leave off the first word! For instance your road is found using Thameside as the area and typing in Park as the road. Scroll down the options that appear and the ones beginning with West will be at the bottom of the list.
Daft, I know, but it works.
Tim
bazzaNW
PostPosted: Sun Jan 16, 2005 6:07 pm    Post subject: just found it Reply with quote
I was searching for another street beginning with P when up popped west park avenue. Thanks a lot for your time
22.054 (22 May 24)
