Trev Occasional Visitor
Posted: Thu Jan 06, 2005 11:05 pm Post subject: tom tom no go |
Hi all
Had my ttg a week now had a good trip in the new year
Today mmmm loss of signal on main roads eg m25
do trees cut out signals?
Then to cap it off approaching a roundabout the screen spins round and round I go straight over but the ttg freezes
I tried to turn it off but it wouldn't go off, so reset it. Then
turned it back on, it does the start up bit
then all i get two red hands and tom tom logo and no maps etc
Trev |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Fri Jan 07, 2005 12:09 am Post subject: |
eject and re-insert the card while the GO is on, see if that helps. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
rkm_hm Frequent Visitor
![](modules/Forums/images/avatars/gallery/web.jpg)
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Fri Jan 07, 2005 1:23 am Post subject: Re: tom tom no go |
Trev wrote: | Then turned it back on, it does the start up bit
then all i get two red hands and tom tom logo and no maps etc |
I got very similar symptoms when I installed v4.40 from the CD onto a new SD card. When this happened, I couldn't turn it off, and had to reset it with a paper clip. The SD card which came with TTG had v4.420 on it - which was ok. When I copied this onto the new card, that was ok too.
What version are you running? If it's 4.40, download and install the latest 4.420 version from the TomTom site.
[I have mentioned problems with 4.40 in other threads, but no-one else seems to have reported this problem until now. Nevertheless, I suspect there's something odd about 4.40] |
Posted: Fri Jan 07, 2005 7:19 am Post subject: |
Thank for the reply
I think its version 4.420
I have eject and re-insert the card while the GO is on and all I get is the two red hands and the tom tom logo
I am useing the card that come with the TTG
I have Speed Cameras on the card
I forgot to mention i can pass POI before TTG tells me
Trev |
Posted: Fri Jan 07, 2005 9:55 am Post subject: |
Trev wrote: | I think its version 4.420
I forgot to mention i can pass POI before TTG tells me |
You THINK it's 4.42 - but can you make absolutely sure, because I think it's important.
If you can get the thing to work - at least temporarily - tap the bottom right-hand corner of the screen when the map is displayed, and it will tell you the software version.
[When I had the problem, I found that it would usually work at the second attempt. In other words, insert the card and turn it on. It reads the card and then hangs, displaying the hands. Reset it with a paper clip. Turn it on again. This time, the map appears - eventually.]
If you can't get the thing to work at all, it may be possible to find the version by viewing one of the files on the card from your PC - assuming the USB interface still works - but I don't know which file. Help, anybody?!
With regard to passing POIs before getting a warning, is this just speed cameras or does it include the built-in POI's? Does it always happen? It's inevitable that one or two speed cameras will be missing from the database, or in slightly the wrong place. Have you told it only to warn of POIs on your route - because you can easily miss some this way? It's safer to turn off this option. |
Posted: Fri Jan 07, 2005 9:19 pm Post subject: |
Thank for the all the replyes
rkm_hm it missed a two and no it will not show any maps just the 2 red hands and logo
As i have only had the TTG for 1 week still learning
To day I phoned Global Positioning systems (spotlight guides ltd)
and told them of the fault thay gave me a return number and new unit will be sent out
So thanks again for your posts
Trev |
Posted: Fri Jan 07, 2005 9:43 pm Post subject: |
Trev wrote: | rkm_hm it missed a two and no it will not show any maps just the 2 red hands and logo |
By "missed a two" do you mean it was 4.40 instead of 4.42?
If so, it confirms my suspicion that there is a problem with 4.40.
You could actually download and install 4.42 - and it would probably be ok - but if they're replacing it, that's probably better.
Do make sure you're getting the latest version though - there still seem to be a lot of earlier versions in stock with various suppliers! |
