Pocket GPS World :: View topic - Bluetooth request device again and again and again .......
Steuart
PostPosted: Fri Dec 31, 2004 4:57 pm    Post subject: Bluetooth request device again and again and again ....... Reply with quote
HP IPAQ2210/ TT3.07/ Holux 230
Having just installed the above it seems to work fine but a few minutes later requests me to choose a BT device.
I reselect the holux and instantly it asks me to do the same again!
Any ideas?
PostPosted: Fri Dec 31, 2004 11:46 pm    Post subject: Reply with quote
Use a registry editor, and set BTBrowserEnabled to zero. There are a few threads in this forum on how to do this.
Steuart
PostPosted: Wed Jan 05, 2005 11:01 am    Post subject: Reply with quote
Many Thanks
Sounds a bit advanced for a novice! Any recomendations for an editor?
Since I posted I re-installed TT3 and used an update from the TT site. I also installed BT Tweak.
The original problem seems solved but now I get intermittent warnings that GPS data is not reliable which fixes instantly. This is despite having 6 or 7 sats logged.
Any Ideas?
PostPosted: Thu Jan 06, 2005 6:04 am    Post subject: Reply with quote
Then you should have posted in the Beginners lounge and not the Advanced lounge...
Steuart
PostPosted: Thu Jan 06, 2005 11:25 am    Post subject: Reply with quote
An oversight but many thanks for the help.
Can this be transferred to the beginners Lounge?
Privateer
PostPosted: Thu Jan 06, 2005 11:49 am    Post subject: Reply with quote
Hi Steuart,
No problem, I've moved this thread to the beginners lounge.
I'm afraid that I can't recommend a registry editor. If I get time I'll have a search through the forum. Smile
Robert.
Garmin Camper 770 LMT-D
barryd
PostPosted: Thu Jan 06, 2005 12:46 pm    Post subject: Reply with quote
Hi Steuart
I'm using the same setup as you, including the BTRegTweak program (which calls itself "Bluetooth Tweaker" when you run it). This program is already changing the setting of the registry key that Lutz mentioned. It sets the value to 1 if you choose Manual or 0 if you choose Automatic. So selecting Manual should indeed fix the problem without resorting to a registry editor.
I usually turn on the Holux before the Pocket PC, and those few seconds are ample time for the GPS to get a good fix before TomTom has finished loading. So I only ever see a GPS position unreliable message if the GPS doesn't have a clear view of sky, and as you say it then clears immediately when I move on from the tree/bridge I'm under.
Hope this helps
Barry Davies
Steuart
PostPosted: Thu Jan 06, 2005 8:35 pm    Post subject: Reply with quote
I have done a full reflash after a hard reset using HP website program.
Tried to run bttweak and now get an error message "Widcomm registry key not found!"
Who said IT is easy hehe
Steuart Whitfield
NAVMAN icn530
iPAQ 2210: Sandisk 1Gb SD card, Holux GR230,
TTNav3.07 (442), CheckPOInt 2.0.2, BtRegTweak
barryd
PostPosted: Thu Jan 06, 2005 9:12 pm    Post subject: Reply with quote
Just a guess, but have you made the BT connection at least once before trying to use BTRegTweak? The key may not be created until you've done so.
For reference, if you do end up getting a registry editor after all, the key I'm talking about is called this on my 2210:
HKEY_LOCAL_MACHINE\SOFTWARE\Widcomm\BtConfig\AutoConnect\0008\BtBrowserEnabled
Good luck!
Barry Davies
Steuart
PostPosted: Thu Jan 06, 2005 10:43 pm    Post subject: Reply with quote
I have connected to BT dongle on my laptop successfully but the error message still comes up when I try to run BT Tweak.
Steuart Whitfield
NAVMAN icn530
PostPosted: Fri Jan 07, 2005 5:29 am    Post subject: Reply with quote
Steuart,
this needs to be done on the Pocket PC, not on the PC.
You find a registry editor here www.phm.lu
This thread explains in more detail what you need to do
http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=3586
Steuart
PostPosted: Fri Jan 07, 2005 9:57 am    Post subject: Reply with quote
Thanks Lutz.
I understood that I needed to bttweak on the PPC but I was trying to test it on the PC BT connection. This was last night.
Barry on my way into work I connected to the Holux and afterwards BTTweak worked well.
I havnt been able to test out the GPS reliability problem again but will get back to you.
Many Thanks to you botth.
Steuart Whitfield
NAVMAN icn530
