LT4play Occasional Visitor
Posted: Sun Jan 02, 2005 6:42 pm Post subject: newbie: Navman iCN-510 memory |
I just ordered my Navman iCN-510 (US model) last night.
I want to get my memory card on order before it gets here.
I have read that SD is faster than MMC, so I plan to order SD.
(someone tell me if I am wrong?)
The Navman website seems to indicate a 512MB card is the maximum, but I see others on this forum saying 1GB will also work. Any problems experienced using 1GB cards?
I assume the Navman is never writing to the card? (i.e., do I care about write performance, or only read?)
Any good manufacturers recommended?
* I have found that PQI has good all-around performance.
* Kingston has good read performance, but slow write performance.
Is it worth getting an Elite/Ultra/etc brand card, or will the "regular" card have sufficient performance (if I buy the write brand)?
Thank You for any help you can provide!
I am exited to experience the world of GPS. |
Brandon78 Occasional Visitor
![](modules/Forums/images/avatars/gallery/040.gif)
Posted: Sun Jan 02, 2005 7:44 pm Post subject: |
I am using a Kingston 512MB SD. I too was wondering if I should buy one of the faster ones, but since I got such a good price ($25 after rebate) on this one, I took a chance. It works fine. I can't imagine a faster card would be any better. It woulnd't make a noticeable difference.
As for the size, I only use 512 so I can't comment on if a 1G would work. However, many people do seem to be using them.
Good luck. |
Posted: Mon Jan 03, 2005 2:19 am Post subject: |
Quote: | The Navman website seems to indicate a 512MB card is the maximum, but I see others on this forum saying 1GB will also work. Any problems experienced using 1GB cards? |
The guy at Outpost.com says that to use the 1GB card in the Navman, that I would need to partition it into two-512MB partitions. That the Navman would not access all 1GB of data at the same time.
Is this correct? If so, is there really any advantage of having a 1GB card instead of a 512MB card, other than having to not switch cards? |
rentboi Occasional Visitor
Posted: Mon Jan 03, 2005 3:54 am Post subject: |
i'm using a 1gb lexar (32x) sd card in mine without any problems. i do not have any partitions on the card, just used it straight out of the box.
do remember to only select one or two maps as active at any time (in settings menu). at first i checked all the maps and the unit became extremely slow, especially when locating poi's; it also crashed a lot. a nice tech support person at navman usa stated that 1gb cards can be used, but don't have too many maps checked all at once; it's been running fine ever since.
good luck!
-alex |
Posted: Mon Jan 03, 2005 4:11 am Post subject: Re: newbie: Navman iCN-510 memory |
rentboi: Thanks for your reponse.
Which 1GB card do you use?
Any comments regarding these other questions?
LT4play wrote: |
Is it worth getting an Elite/Ultra/etc brand card, or will the "regular" card have sufficient performance (if I buy the write brand)? |
larkshall Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Joined: Nov 11, 2004 Posts: 112 Location: Selby North Yorkshire
Posted: Mon Jan 03, 2005 1:13 pm Post subject: |
I am using both a 1gb sandisk, and a 1gb fuji SD card in mine. (One has UK maps and Northern Europe), the other has southern europe on. No problems with either card
regards
David Low |
firediver Occasional Visitor
Posted: Sun Jan 09, 2005 4:11 pm Post subject: I am using a 1 GB pqi SD card |
I have had my 510 less than a week but the system recognizes the 1 GB card and I have had no problems with it. I am using it in the NE USA.
The manual does say it will only handle a card up to 512 MB.
Performance seems fine.
outpost.com had a great deal on the GPS systems and the SD card
ICN 510 - $299 US
1 GB SD card - $65 US after rebate
They dont have it available for export but its still at a reasonable price now $329.
-Jason |
jowook Occasional Visitor
Posted: Thu Jan 13, 2005 11:52 pm Post subject: |
Brandon78 wrote: | I am using a Kingston 512MB SD. I too was wondering if I should buy one of the faster ones, but since I got such a good price ($25 after rebate) on this one, I took a chance. It works fine. I can't imagine a faster card would be any better. It woulnd't make a noticeable difference.
Good luck. |
Brandon78,
I'd appreciate, if you let me know where you got that one. $25 is pretty good deal. |
