Pocket GPS World :: View topic - TomTom wired receiver failing to lock on
Goto page Previous  1, 2
lbendlin
PostPosted: Tue Dec 21, 2004 7:43 pm    Post subject: Reply with quote
It sounds like your receiver is living through it's last days... can you try using a different receiver (borrow one somewhere)?
Lutz
TomTom/TeleAtlas NAVTEQ
Heyou
PostPosted: Tue Dec 21, 2004 8:03 pm    Post subject: Reply with quote
Yes i feel that's the case too. Maybe i should get somone to try using mine and see what happens for them?
cheers
Good judgement comes from experience. Experience comes from bad judgement
TonyP
PostPosted: Sun Dec 26, 2004 4:16 pm    Post subject: Reply with quote
This is the same problem that I have with my Haicom. Works perfectly when its new, then after a while takes ages to get a fix.
I assume it is a problem with the backup battery, but they are not replacable, so it means getting a new GPS.
I came here to see if Leadtek is any better, but it doesnt seem to be.
Same problem in the Holux forum
Maybe we should have a poll to see which GPS mouse is likely to last longer for a year.
Heyou
PostPosted: Tue Dec 28, 2004 1:46 am    Post subject: Reply with quote
can i get clarification on the backup battery thing! Does a wired GPS receiver have a battery in it? and can it be changed?
cheers
lbendlin
PostPosted: Tue Dec 28, 2004 6:41 am    Post subject: Reply with quote
yes, it has a battery. No, it cannot be changed.
Lutz
Heyou
PostPosted: Tue Dec 28, 2004 1:54 pm    Post subject: Reply with quote
OK, looks lke it's time to buy another mouse :x
Heyou
PostPosted: Sat Apr 16, 2005 10:03 pm    Post subject: Reply with quote
Anyone know what this batteries identity is??
It's on the underside of the circuit board, i didn't think there was battery at first it's so small, and it's what's causing my wired GPS to take forever to get it's first fix.
Description :-
The only things written on the battery are :-
on the side of it "0302"
on the positive face :- "IIS" and "made in Japan"
It may have more writing on it but it also has 2 circuit board solder tags spot welded to it, covering up any more info. I think, i've worked out that it's 3 volt?? by plugging in the charging unit and measuring the voltage coming from the battery whilst it's on the circuit board!! but of course i may completely wrong about this.
It never gets to above 2.2volts after being on the DC supply and remove the DC supply and it drops down to .6 volts within a few hours.
I've emailed Leadtek, no response, and i guess they won't tell me what the battery anyway, only that they'll repair the unit for a price!! I know i can fix this if only i could source a battery for it.
So what i'm after is - 3volt ? - 6.5mm Dia. X 1.5mm height.
I'm pretty sure it's rechargeable.
It has 2 solder tags on it but i won't hold my breath - i could modify it to solder it to the circuit board.
cheers
Del.
Here's the little critter
Page 2 of 2
