Pocket GPS World :: View topic - Fotuna Clip-On - Destinator Sync Prob ?
Samali
PostPosted: Fri Dec 03, 2004 6:15 pm    Post subject: Fotuna Clip-On - Destinator Sync Prob ? Reply with quote
Hello,
For my friend who has Fortuna Clip-On BT GPS and Destinator-3, He can't sync. both devices. Any one knows how and which Port Com, Baud Rate and Protocol to use.
He tried auto. config but can't get any result, also the 2 devices are connected in the BT manager.
Any help please
DavidW
PostPosted: Sat Dec 04, 2004 5:08 pm    Post subject: Reply with quote
If the Fortuna is at factory defaults, NMEA at 38400bps. The serial port to use is dependent on the Pocket PC used.
If the Fortuna isn't at factory defaults, turn it off, slide the ST/XT mode switch, wait a couple of seconds and slide the mode switch back - which will reset it to factory defaults.
Samali
PostPosted: Sun Dec 05, 2004 12:47 pm    Post subject: Reply with quote
Hi Dave and thanks for your reply.
After reading several posts I solved the prob. with this (if it helps any one):
- Remove the battery for a few seconds
- Re-fix the battery in its place
That is all, the devices communicate and Tomtom works fine.
