Pocket GPS World :: View topic - DConnex DC-230 / TomTom Navigator 3 and MDAII
eDsuB
PostPosted: Thu Nov 25, 2004 11:45 pm    Post subject: DConnex DC-230 / TomTom Navigator 3 and MDAII Reply with quote
I still have some trouble with the mentioned combination and thanks a friend I managed to narrow the cause to the combination of TomTom and the DConnex:
I am unable to confirm in TomTom GPS the 'Bluetooth GPS' port when I have paired the DConnex.
I am able to confirm in TomTom GPS the 'Bluetooth GPS' port when I have paired a Globalsat BT-308 BT GPS (and NOT creating a serial port!).
Only way to get the DConnex working in TomTom is to pair is and create a serial port. In TomTom you have to select COM5.
The configuration on COM5 works with TomTom as long as there is a BT Connection. When there is NO BT connection, the MDAII hangs upon starting TomTom.
With the 'Bluetooth GPS' configuration (=not possible with DConnex) TomTom works even when there is no BT connection!
As I did not find any answers here, on xda-developers.com and with TomTom Support, I guess I hav to live with this situation.
STILL: Any help / sugestions are greatly apppreciated!!!!
eDsuB
T-Mobile MDA Vario IV
TTN7 / iGo8
alix776
PostPosted: Sat Nov 27, 2004 7:31 pm    Post subject: Reply with quote
hi edsub you need to select blue tooth gps in the lower list in the navigator gps set up screen reather than selecting a bt with comport that should do it
device Lumia 950 xl
eDsuB
PostPosted: Sat Nov 27, 2004 8:27 pm    Post subject: Reply with quote
Alix,
I tried all combinations.
Issue is that with the DConnex I cannot check the blue box when i select Bluetooth GPS in the lower box.
Selecting NMEA ....Bluetooth or NMEA ....<baudrate> in the upper box makes no difference.
Like I said issue os there only with the DConnex GPS. Not with ie. a Globalsat GPS
eDsuB
TTN7 / iGo8
alix776
PostPosted: Sat Nov 27, 2004 10:28 pm    Post subject: Reply with quote
have you tried the gps unit with another pda say an ipaq or somehting you should be able to check the box what version of tt are you useing and have you tried gps 2.07
device Lumia 950 xl
eDsuB
PostPosted: Sun Nov 28, 2004 12:20 am    Post subject: Reply with quote
havent tried with another pda.
am using version 3.03
So far TomTom Support doenst have a clue
Just the different behaviour between the DConnex and the Globalsat, plus the experiences with non-DConnex GPS's I heard from others on xda-developers.com led to my conclusion it must be the DConnex (might be in combination with the MS Bt Stack of the MDAII).
eDsuB
TTN7 / iGo8
eDsuB
PostPosted: Fri Dec 17, 2004 4:17 pm    Post subject: Reply with quote
Update: The issue I have (and not only me) seems to be solved with the (non-official) WM2003 SE ROM upgrades for the XDAII/MDAII.
eDsuB
TTN7 / iGo8
