Ann Occasional Visitor
Posted: Fri Nov 19, 2004 1:50 pm Post subject: That stupid re-aligning page! |
Hi guys
Ok quite often I dont use my medion for a while and when I return to it I have to go through the setup and do the copy and paste stuff. I hate doing this, is there a way to bypass it please?
Thanks for any help
Ann |
OBH6UK Occasional Visitor
Posted: Fri Nov 19, 2004 2:19 pm Post subject: |
Charge it at least once a week. Or don't but backup the device and then realign each time and then restore. |
Posted: Fri Nov 19, 2004 3:40 pm Post subject: |
Hiya and thanks for your reply.
The charging once a week is never gonna happen as I keep it in my drawer upstairs and I forget!
I dont really know what you mean by that bit, I havent told it to restore? I havent changed it at all?
Ann |
DavidW Pocket GPS Moderator
Posted: Fri Nov 19, 2004 5:41 pm Post subject: |
Pocket PCs require battery power to maintain their memory, as the main memory is RAM for speed reasons.
If you let the battery go flat, the Pocket PC will hard reset - which returns it to its 'factory fresh' state. Whilst your Navigon software clearly survives this, I expect any custom settings and similar will be lost.
I'd strongly recommend leaving the machine on charge when it's not in use - Lithium Ion batteries don't like being run flat and can be damaged that way. It'll also save you the hassle of going through the screen alignment - there is no way around that if the device has lost power.
If you want to restore settings and the like, I recommend Sprite Backup - but you still have to align the screen to restore a Sprite Backup file.
David |
Posted: Fri Nov 19, 2004 7:24 pm Post subject: |
Hi David and many thanks for you reply.
Right I see, i'll probably just have to leave it on charge then. No the software doesnt survive it, I still have to reinstall navigon but its not a long job. Its just the stupid screen alignment and then the 'how to' cut and paste etc that I have to go through everytime!
Thanks again
Ann |
