dunno Regular Visitor
Posted: Sun Oct 24, 2004 8:52 pm Post subject: active sync |
since installing the new service package i have been unable to sync pc ppc (well to be more honest it's been ages since i tried but is before i installed the update).i can see it on the pc in my computer but if i try and explore there is nothing there also i have tried restalling it up but it doesn't want to know
ipaq2210 2003 & windows xp home linked via cradle
any ideas will be appreciated ,thanks |
lbendlin Pocket GPS Staff
Posted: Mon Oct 25, 2004 1:13 am Post subject: |
that's a common issue with XP, especially after SP2. Try reinstalling ActiveSync 3.7.1 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Dave Frequent Visitor
Posted: Mon Oct 25, 2004 7:25 am Post subject: |
3.7.1 is the problem, downgrade to 3.7 or below and it will be okay. There's download links on our download menu to various ActiveSync versions.
It's a known Microsoft bug that Microsoft STILL hasn't fixed. |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Mon Oct 25, 2004 12:12 pm Post subject: |
Thats strange?
I have SP2 installed and I use active Sync 3.7.1
I can sync to the PPC and everything works fine with no problems at all.
In fact after reading horror stories about SP2 I didn't want o install it but as I had automatic updates switched on and SP2 had started to install automatically I decided to let it finish. Nedless to say I needn't have worried as I have not experienced any issues with it at all. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Mon Oct 25, 2004 12:26 pm Post subject: |
I too have Win XP (Pro) with SP2 installed. I have ActiveSync 3.7.1 (Build 4034) and like icsys have had no problems. _________________ Tim |
Posted: Mon Oct 25, 2004 2:11 pm Post subject: |
yeah, it works fine until you start using more than one pocket pc on the same active sync PC. AS gets confused after a while and doesn't show the folders any more. Interestingly enough the way via the "My Computer . Mobile Device" may still work, and the way via the dev tools (Remote File Viewer WILL still work. Sometimes killing wcescomm.exe helps, sometimes a rebot, sometimes just patience. _________________ Lutz
Posted: Mon Oct 25, 2004 2:18 pm Post subject: |
Sorry Lutz, but my 3970 and 5555 are definitely different and both work just fine on the same PC. I guess that my situation is the exception that proves the rule.... _________________ Tim |
Posted: Mon Oct 25, 2004 2:28 pm Post subject: |
Do you have your PC setup to have partnerships with both devices?
I can't afford that because I use multiple PCs to connect to multiple pocket pcs, and have set AS to automatically only accept guest connections - maybe that's contributing, too. _________________ Lutz
Posted: Mon Oct 25, 2004 2:37 pm Post subject: |
Yes I do. _________________ Tim |
Posted: Mon Oct 25, 2004 3:10 pm Post subject: |
thanks for the replies ,yes i did try go back to 3.7 and it still didn't work on my pc ,so i reinstalled 3.7.1 ,i'll go back to the old 1 and try a few more times and see what happens |
Posted: Mon Oct 25, 2004 3:25 pm Post subject: |
Make sure your cradle is unplugged from your PC when installing activeSync otherwise this could cause you problems synchronising with the PDA. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Sat Nov 13, 2004 4:35 pm Post subject: |
i ended up doing a go back on my ppc & now it works ,so it must have been something wrong on my ppc |
