Pocket GPS World :: View topic - Samsung Phones and Android 10
Goto page Previous  1, 2
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android
mol2
PostPosted: Wed Jan 13, 2021 6:26 pm    Post subject: Reply with quote
Still not working on Samsung S10e running Android 10.
FrequentFlyer
PostPosted: Fri Mar 12, 2021 10:11 am    Post subject: Reply with quote
I miss CA do much, I'm going to buy another phone. Question. What is the last Samsung phone that will run CA ? Thanks.
PostPosted: Fri Mar 12, 2021 10:21 am    Post subject: Reply with quote
It's hit and miss but you need a phone that's going to stick on Android 9 (Pie) and not update. My guess would be a Galaxy S7.
I've been looking at a decompiled CA in a few APK tools and it looks like the issue is AndroidX and the new API's.
There are 2 lines that need adding into the .gradle then Android Studio may be able to convert the code.
I can't get in too deep because not all the support files are available but the error seems to be the way AndroidX handles the 'filename.9.png' initial splash screen.
Android uses the '*.9.png' as an instruction to resize the splash screen to the phones screen size.
This is where it seems to be falling over.
PostPosted: Sat Mar 13, 2021 2:12 pm    Post subject: Reply with quote
My OnePlus 5 running Android 10 runs the app fine. As does my recent Huawei P30 Lite NE (Android 10).
I know it fails on Pixel 2 running Android 11.
Aside from that, I don't know cos I don't use Samsung...!
PostPosted: Sat Mar 13, 2021 2:16 pm    Post subject: Reply with quote
Interesting. The 9-patch files (*.9.png) are still valid in the Android SDK so it may be how Samsung's version of Android 10 specifically handles the file?!
Unless the error is just AFTER the 9-patch file loads and that file is the last thing that successfully loads and gets logged?
PostPosted: Sat Mar 13, 2021 5:32 pm    Post subject: Reply with quote
Could be.
I'm also suspicious of how AndroidX handles map files, which could be the next thing it does. On my Android 9 tablet, after the splash it loads the map.
Sadly I'm no Android expert.
One thing I did find is using the Android Studio AVD which mimics an Android phone for testing, that also falls over, but I did set it to mimic a Pixel2 which is the default.
Leo_A
PostPosted: Mon Mar 15, 2021 7:42 pm    Post subject: Reply with quote
Starting from Android 9, if the app uses Google Maps, its manifest must include the following line
Code:
<uses-library android:name="org.apache.http.legacy" android:required="false" />
in the application section.[/quote]
PostPosted: Tue Mar 16, 2021 4:59 am    Post subject: Reply with quote
Interesting.
I've had a clearout so I'll reinstall the bits I need to get at the manifest.
In the main the AndroidManifest.xml is read only but APKLab via Visual Studio code does allow editing.
PostPosted: Tue Mar 16, 2021 6:33 am    Post subject: Reply with quote
Line inserted.
Still works on tablet under Android9 but won't run under Android10
Sad
The more I dig into the error:
java.lang.ClassNotFoundException
BaseDexClassLoader.java
dalvik.system.BaseDexClassLoader
findclass
Could this be the error line (3340), as pointed at by the crash dump:
invoke-interface (v0, v1, v2), Landroid/content/SharedPreferences;- getString(Ljava/lang/String;Ljava/lang/String;)Ljava/lang/String;
Some characters edited out due to posting issue
Double dutch to me
It's trying to invoke java lang and it's java lang that it can't find. Trying to find exactly where the link is to see what it's calling is baffling me.
CAA_0818232231
PostPosted: Sat Mar 20, 2021 10:13 pm    Post subject: Samsung S20 + 5G - Android 11 Cameralert Not Working Reply with quote
I have a Samsung S20 + 5G running:
- Android 11
- One UI version 3.1
So it would seem the problem of cameralert has progressed to the latest version of android.
PostPosted: Thu Nov 28, 2024 12:51 pm    Post subject: Reply with quote
Hopefully this will trigger some email updates to everyone in the thread who couldn't run CamerAlert on Android 10 and newer:
You will be pleased to hear that the app has now been updated and can be downloaded here: https://play.google.com/store/apps/details?id=com.pocketgpsworld.cameralert
FrequentFlyer
PostPosted: Thu Nov 28, 2024 1:59 pm    Post subject: Reply with quote
Thanks for your hardwork.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> CamerAlert on Android All times are GMT + 1 Hour
Page 2 of 2
23.045 (30 Apr 25)
