Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Sat Nov 21, 2020 12:06 am Post subject: Unable to copy POIs to computer |
I want to copy the POIs from one Via 135 to another, so I go to "Manage community content" in MyDrive Connect and in the POI list I click on "Copy to computer" next to a POI category.
Two IrfanView screens open, one showing the bmp and the other showing the message "....ov2: Can't read file header! Unknown file format, empty/damaged file or file not found!" This happens with both Via 135s, and there's no problem navigating to or managing POIs on either device..
I've never had a problem copying POIs to my computer in the past, although I haven't done it for some time.
I'd be very grateful for any suggestions as to how I might overcome this problem. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Kremmen Pocket GPS Verifier
Posted: Sat Nov 21, 2020 5:16 am Post subject: |
Can you use Windows file explorer to see these bmp and ov2 files and copy them across manually.
TT do seem to be crippling devices by insisting you use their bugged programs to manage them. _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Nov 21, 2020 10:56 am Post subject: |
Thanks for your reply, Kremmen.
As far as I know there is no way to access these files until they've been copied to a computer and, instead of asking where the files should be saved as in the past, it tries to open them in IrfanView. I've saved the bmp, which seems to be absolutely normal but, of course, the ov2 file won't open.
I've downloaded POIViewer10 and made it the default for opening POI files, but IrfanView still attempts to open it and fails. _________________ Anita
UK map 1130.12368
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Nov 21, 2020 11:50 am Post subject: |
Something you could try.
In File Explorer, Right Click an OV2 File and choose properties.
Under the General tab, look for 'Opens with:'.
You can select the Change button to choose an app that works for you. Mine is set to PoiEdit.
I can't replicate the problem you have. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Posted: Sat Nov 21, 2020 12:13 pm Post subject: |
Thanks, Oldboy.
That's what I've done, using POIViewer10, making that the default for opening OV2 files, but when I click on "Copy to computer" in MyDrive Connect/Manage Community Cotent, Irfanview opens the BMP file and tries to open the OV2 file and fails.
If it works OK for you it must be something to do with my laptop. I'll investigate the settings for IrfanView. _________________ Anita
UK map 1130.12368
Posted: Sat Nov 21, 2020 1:14 pm Post subject: |
I'm not near my PC to investigate but there is a way to cancel 'file associations'.
OV2 must be set on yours with a default program.
I'll be home monday to check if this is still a problem.
I was just thinking a simple copy/paste from one device to the other. That shouldn't need any file association. _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Nov 21, 2020 1:48 pm Post subject: |
You can't copy and paste, the only way to access the files is through MyDrive Connect!
Changing the file association for OV2 files to POIViewer10 or POIEdit doesn't stop IrfanView from trying to open it.
However, I think it may be something to do with Firefox, my usual browser, because I've just tried using IE and it copies the OV2 file to my computer!! _________________ Anita
UK map 1130.12368
Posted: Sat Nov 21, 2020 3:11 pm Post subject: |
Anita wrote: | However, I think it may be something to do with Firefox, ... | I also use Firefox, by default  _________________ Richard
Posted: Sat Nov 21, 2020 3:29 pm Post subject: |
Me too, Richard, but for some reason this is working in both IE and Edge but not in Firefox  _________________ Anita
UK map 1130.12368
Posted: Sat Nov 21, 2020 7:02 pm Post subject: |
In Firefox, select Tools, from the Menu Bar, then choose Options.
Under the General tab (the default), scroll down to the Applications section.
In the Content Type selection field, Left Click the OV2 entry. At the right of the highlight should be a Drop Down Box. Select 'Always ask'. _________________ Richard
Posted: Sat Nov 21, 2020 8:33 pm Post subject: |
The Content Type doesn't include OV2 or TomTom Binary.
'Always ask you where to save files' is selected under Downloads.
Thanks for trying to help, Richard, but I'll just have to use IE or Edge for copying POIs to my computer. _________________ Anita
UK map 1130.12368
Posted: Sun Nov 22, 2020 10:28 am Post subject: |
The only other thing to try is to reset the Download Handler.
See https://support.mozilla.org/en-US/kb/change-firefox-behavior-when-open-file
You should then get the What do you want to do with this File window, and be able to chose 'Do this automatically ...' _________________ Richard
Posted: Sun Nov 22, 2020 11:25 am Post subject: |
Thank you so much, Richard. That seems to have worked!  _________________ Anita
UK map 1130.12368
BrodVictor Spammer
Posted: Mon Apr 26, 2021 9:22 am Post subject: |
[nonsense post - removed by MaFt] |
