Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Wed May 13, 2020 5:06 pm Post subject: |
Let's see if the same occurs tomorrow with the new files.
If so I'll debug to see what's happening. _________________ Satnav:
Car Average MPG :
jonial Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_et_003.jpg)
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Wed May 13, 2020 5:12 pm Post subject: |
I have now done as Dales did deleted the .csv files rerun the Direction converter again the ran the CSV to GPX converter and all is now OK.
Thanks to you all for your help _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
Posted: Wed May 13, 2020 5:21 pm Post subject: |
Part of the unzip routine is to delete any existing .CSV or .GPX files so each run starts with a clean slate.
I've just run it neat, start to finish, using all camera types and all OK here as well.
X Files ? _________________ Satnav:
Car Average MPG :
Posted: Wed May 13, 2020 5:26 pm Post subject: |
Just put it down to the Lockdown !!! _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Wed May 13, 2020 5:28 pm Post subject: |
Double check on code:
Yep, deletes CSV and GPX before unzipping. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Wed May 13, 2020 7:12 pm Post subject: |
I used both CSV-GPX and DIR converter earlier with today's files including pMobiles both times and had no problem.
Are you telling me I should have? |
Posted: Thu May 14, 2020 6:23 am Post subject: |
What I don't understand is how the unzipped mobile file(s) contained the same data twice in the same list with 2 headers and presumably 2 footers.
Also, why a manual .csv delete was needed. A new download and unzip should have deleted all existing csv files.
Never happened before and working OK now.
The only logical conclusion is that there was a temporary blip with the downloaded mobile files.
If it happens again, I can work round it. I'll wait to see if it's a one off.
I would have thought if there was a data problem then we wohld have seen this posted earlier in the week. It happened on a Wed, just before the latest update. _________________ Satnav:
Car Average MPG :
Posted: Thu May 14, 2020 7:13 am Post subject: |
Because of the lockdown my car is hardly used, perhaps once a month, so I do not update regularly. I did discover the problem when I tried to do a random update over last weekend but thought it was a blip and when I tried again on Wednesday and had the same error I decided to Post it to this forum. I will try to update later today to the latest version and report back. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Thu May 14, 2020 7:54 am Post subject: |
I've just downloaded todays and all OK.
If this does become problematic then I can 'spot' the unexpected word 'Latitude' in Col 1 and set the end of file (EOF) so it stops reading the file and carries on to the next file.
If you do get it can you save the rogue file(s) so I can get it for investigation to make doubly sure it is the same data twice so terminating the file read is OK. _________________ Satnav:
Car Average MPG :
Posted: Thu May 14, 2020 8:03 am Post subject: |
I have just checked the PGPSW Folder on my PC and the *.csv files are no longer there. I will try an update later on today _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Thu May 14, 2020 8:28 am Post subject: |
I have found all the *.csv files in my Recycle Bin. How can I forward one or all to you ? _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Thu May 14, 2020 8:30 am Post subject: |
I think at the moment, if OK with everyone, that I'll wait for another one that hopefully won't occur.
Never happened before so hopefully ....... _________________ Satnav:
Car Average MPG :
Posted: Thu May 14, 2020 8:38 am Post subject: |
I restored the .csv files to the working folder (PGPSW) re processed them in Direction converter when that completed I the Processed in gps converter and it failed with the same error. On looking into th .csv files it appeas as thought there may be two sets of data. But they were not deleted. _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Thu May 14, 2020 9:40 am Post subject: |
I have now performed the latest update with no problems at all.
How strange - perhaps operator error !!! After all I am a Silver surfer.
Thanks to all for the help and info _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
Posted: Thu May 14, 2020 9:54 am Post subject: |
No, not your issue, Dales saw it as well and I know he is PC literate _________________ Satnav:
Car Average MPG :
