b33jay Lifetime Member
Posted: Wed Sep 25, 2019 2:50 pm Post subject: Specs warnings |
Specs 202161/202163 are now on the CamerAlert database and I passed through the zone yesterday. The first camera triggered a specs alert and the vehicle speed and average speed appeared on the screen but a few hundred yards further on both speeds disappeared. Unfortunately, I didn't return by the same route so couldn't check how it worked in the opposite direction. |
Kremmen Pocket GPS Verifier
Posted: Wed Sep 25, 2019 3:07 pm Post subject: |
I can see 202160 thru 202163 on Luton Rd / Bedford Rd
They look OK with no intermediate cancel points so should have remained active between the 2.
@MaFt, I can't see any dummy off points on any of the side roads like Duck End Lane or Cotton End Rd. _________________ DashCam:
Viofo A119 V3 |
Posted: Thu Sep 26, 2019 9:37 am Post subject: |
Kremmen wrote: | I can see 202160 thru 202163 on Luton Rd / Bedford Rd
@MaFt, I can't see any dummy off points on any of the side roads like Duck End Lane or Cotton End Rd. |
You mention 202160 not 202161 so there may be three camera numbers but only two cameras.. I submitted these cameras and later added photos and more accurate coordinates which may account for the different camera numbers and, if so, is there now a conflict creating a false cancel point? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Thu Sep 26, 2019 11:30 am Post subject: Re: Specs warnings |
b33jay wrote: | Specs 202161/202163 are now on the CamerAlert database and I passed through the zone yesterday. The first camera triggered a specs alert and the vehicle speed and average speed appeared on the screen but a few hundred yards further on both speeds disappeared. Unfortunately, I didn't return by the same route so couldn't check how it worked in the opposite direction. |
When you say that both speeds disappeared that, to me, implies that the GPS location was lost. If it was just that the average speed disappeared but still showed you current speed then that would be when you hit the end camera (or a marker on a side street to turn them off). |
Posted: Thu Sep 26, 2019 4:08 pm Post subject: Re: Specs warnings |
MaFt wrote: | b33jay wrote: | Specs 202161/202163 are now on the CamerAlert database and I passed through the zone yesterday. The first camera triggered a specs alert and the vehicle speed and average speed appeared on the screen but a few hundred yards further on both speeds disappeared. Unfortunately, I didn't return by the same route so couldn't check how it worked in the opposite direction. |
An update after a trip through Wilstead today.
1st run northbound:
Got a verbal warning"average speed cameras" then the two average speed icons appeared on screen. After several hundred yards both icons disappeared and the screen showed no camera info.
2nd run southbound:
No camera warning
3rd run northbound:
Average speed camera verbal warning and two average speed icons appeared on screen. These remained on screen until I cancelled them at the A6/A421 junction 1½ miles past the second camera.
4th run southbound: no camera warning at all.
There are two fixed cameras 383/386 on the A6 bypass very close to the average speed camera 202161 would these be having any effect? They appear on CamerAlert so it's unlikely to be a GPS reception problem two hundred yards way.
I also had a drive tound Bedford and the four sets of average cameras appeared as normal on CamerAlert. |
marksfish Pocket GPS Verifier
Joined: Jun 25, 2005 Posts: 802 Location: Sandy, Bedfordshire
Posted: Thu Sep 26, 2019 7:45 pm Post subject: |
I shall take a drive out to Wilstead this weekend and have a look and see what my CamAlert says. _________________ Garmin Drivesmart 51 LMT-D Europe |
Posted: Fri Sep 27, 2019 11:29 am Post subject: Re: Specs warnings |
Just to clarify:
"the two average speed icons appeared on screen. After several hundred yards both icons disappeared"
Do you mean the yellow specs icons that show the location of the cameras on the map? Or do you mean the current speed and average speed at the top left of the screen? If the former then that is intended behaviour - the icons go off the screen and you get the average speed in the top left to monitor - that will beep if you have overspeed warnings on and you go over either the speed or the average speed.
I have tweaked the angles for the 2 most northerly cameras. However I cannot see why they wouldn't alert southbound nor end the average speed northbound.
Can you go to the 'manage cameras' and see if you have any of your own cameras on there? If so then delete them and also re-download the database to pull in the directional changes I've just made. |
Posted: Fri Sep 27, 2019 1:11 pm Post subject: |
Beep ?
On my Android CA I'm sure it constantly warns say '50', '50', '50' until I drop to or below 50, or whatever speed. _________________ DashCam:
Viofo A119 V3 |
Posted: Fri Sep 27, 2019 3:55 pm Post subject: Re: Specs warnings |
MaFt wrote: | Just to clarify:
Yes, current speed and average speed digits.
TWO most northerly cameras?
There is one camera at each end of the village and both are bi-directional!
I haven't ever had any of my own cameras on CamerAlert.
I'll update but next run may be next week. Perhaps Marksfish may reveal more info when he does his run. |
Posted: Fri Sep 27, 2019 4:54 pm Post subject: |
If you look at the area in question there are 2 cameras at each end in the database.
That's why I quoted the 4 numbers. _________________ DashCam:
Viofo A119 V3 |
M8TJT The Other Tired Old Man
Posted: Fri Sep 27, 2019 7:33 pm Post subject: |
And if you get the app Mock Locations (fake GPS path) {Android}, you can simulate a route and don't even have to move beyond your couch. |
Posted: Sat Sep 28, 2019 4:08 am Post subject: |
If the Specs is being cancelled fairly soon after it's being triggered then something is wrong somewhere.
I'd be looking at my Android settings to see if CA has been flagged as not being allowed to run in the background or is being 'optimised', etc.
I'm going to be driving on the M4 a few times next week from junctions 3 to 10, and back. Not sure if any of this smart motorway roadworks are active yet but if so I'll see how mine performs. _________________ DashCam:
Viofo A119 V3 |
Posted: Sat Sep 28, 2019 5:00 pm Post subject: |
Kremmen wrote: | If you look at the area in question there are 2 cameras at each end in the database.
That's why I quoted the 4 numbers. |
Ah, apologies Although there is only one actual camera at each end it needs two virtual cameras to cover the two way operation?
Had to go back to Bedford today to return faulty goods so yet another trip through Wilstead. I use CA on a phone permanently mounted on the dash. This time I also used my regular phone which has CA installed but has not been updated for over 10 days.
Northbound both phones gave the average speed camera warning. Vehicle speed and average speed appeared top left on both screens and remained there until passing the second camera at end of the village
On return southbound the updated in-car phone showed the warning and then both speeds on screen but the regular phone showed nothing. I then updated the regular phone and returned to the A6 and made another run southband and this time both phones gave the warning and showed the two speeds on screen.
Seems whatever was the problem has been sorted. Thank you |
Posted: Sun Sep 29, 2019 10:28 am Post subject: |
No need for me to go then? It was on my "to do" list today.
Mark _________________ Garmin Drivesmart 51 LMT-D Europe |
Posted: Mon Sep 30, 2019 11:43 am Post subject: Re: Specs warnings |
b33jay wrote: | TWO most northerly cameras?
There is one camera at each end of the village and both are bi-directional! |
We can't use 'reversible' cameras in CamerAlert for START or END cameras so we add a duplicate to cover a reversible camera. Hence 2 camera icons at each end of the stretch.
b33jay wrote: | I haven't ever had any of my own cameras on CamerAlert. |
It was just something to check in case you'd submitted them via the app.
MaFt |
