Kremmen Pocket GPS Verifier
M8TJT The Other Tired Old Man
Posted: Mon Jan 08, 2018 5:29 pm Post subject: |
Nice work K. |
Posted: Mon Jan 08, 2018 6:26 pm Post subject: |
When the need arises I'll put in the other x5 mph values. I've been told of a 15mph area in Green Park Reading, but no enforcement.
I've left the 55 .WAV and .BMP in the pack, you never know. _________________ DashCam:
Viofo A119 V3 |
Joined: 30/12/2002 17:36:20 Posts: 4921 Location: Oxfordshire, England, UK
Posted: Mon Jan 08, 2018 7:13 pm Post subject: |
Kremmen wrote: | When the need arises I'll put in the other x5 mph values. I've been told of a 15mph area in Green Park Reading, but no enforcement. |
Jersey (Channel Islands) has a lot of roads called "Green Lanes" where walkers, cyclists, and horse riders have right of way and the speed limit for vehicles is 15 mph. I've not encountered any enforcement on these Green Lanes but there is a possibility I guess, so the ability to handle x5 mph would be useful.
Regards _________________ Robert.
Garmin Camper 770 LMT-D |
Nemesis1 Regular Visitor
Posted: Tue Jan 09, 2018 4:26 pm Post subject: |
Quick one. (You may already know).
While pottering around trying to just get a few icons on my map, no alerts (now being handled by my Garmin Dash Cam) I have loaded various files with icons of various sizes. So I knew what the files were amongst all my normal POI files I called them various names. It appears 'Beware' is a Garmin trigger word, got numerous alerts from that POI file today.
Posted: Sun Feb 18, 2018 12:46 pm Post subject: |
New version 70
I deliberately didn't opt to download the PMobiles in the zip file.
After unzipping, the older PMobile files were still there from the previous download.
The unzip routine will remove any .CSV files found so what is in the working folder is just what you have in your latest downloaded zip.
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0 _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Feb 18, 2018 4:34 pm Post subject: |
Sort of thinking out loud, I wonder if that's what is/was causing other users problems of rogue cameras, although the most recent one was about SPECS. |
Posted: Sun Feb 18, 2018 5:34 pm Post subject: |
If they use my converter then possibly. I noticed by accident that my PMobiles were dated back in December.
If they always download the same flavour including PMobiles then no problem.
Also, I only remove gpx and now csv from the working directory.
I suppose I could look at interrogating any Working Directory sub folders to see if there are any duplicates that are going to be sucked in by POIloader. _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Feb 18, 2018 5:59 pm Post subject: |
Hey, that's not a shabby idea. Or even just flag up that there are sub folders that might contain them rather than delving into them.
And pop up a warning suggesting they delete them or move them elsewhere. |
Posted: Sun Feb 18, 2018 6:21 pm Post subject: |
It's perfectly OK to have sub folders and they may contain valid other POi sets.
If I interrogate them for gatso, mobile etc I can flag that up and ignore the POI's for McDonalds, etc
I'll see what I can do and do a Microsoft test .......
Patch it out and wait for the phone to ring  _________________ DashCam:
Viofo A119 V3 |
Posted: Sun Feb 18, 2018 11:42 pm Post subject: |
Hadn't thought of that K.  |
Posted: Mon Feb 19, 2018 9:26 am Post subject: |
Done
New Option:
Will produce this:
It looks for any Directories under the Working Folder and displays them.
Then, if any of them have a .CSV or .GPX it will list them if they are preceded with:
Gatso*
Mobile*
Redlight*
Specs*
If I need to expand the search then that is easy but my thoughts are that this should highlight any suspect folders whilst it may not list all the rogue files. _________________ DashCam:
Viofo A119 V3 |
Posted: Mon Feb 19, 2018 9:48 am Post subject: |
What about PMobiles?
Does your screendump mean that the rogues are in the 'test csv gpx' but the other subs are 'clean'?
I'll give it a go to see if I can break it later. |
Posted: Mon Feb 19, 2018 10:06 am Post subject: |
My search is for 'instr mobile' so mobile or pmobile are trapped.
It searches every directory under the working directory and shows any suspect files.
In my case I only had rogue files in that directory I setup for testing. _________________ DashCam:
Viofo A119 V3 |
turbo10 Regular Visitor
Posted: Fri Feb 23, 2018 10:09 am Post subject: |
I have just attempted to install CSV to GPX program onto a new laptop and when I run it it says "You cannot start application CSV to GPX converter from this location because it's already installed from a different location"
I have had this before many months ago and can't think for the life of me how I got around the problem.
Any help please?
Thanks _________________ Triumph Tiger 800 XRt
Garmin Zumo 595LM
TomTom Live Truck
Samsung Galaxy S7 Edge |
