M8TJT The Other Tired Old Man
Posted: Fri Aug 04, 2017 7:45 pm Post subject: |
Metblackrat wrote: | Is this compatible with the European cameras? | No. Quote: | I've just tried it with the Europe, speed zoned complete and it throws up a load of errors. I'm guessing it's to do with the higher speed limits as they are stated in KMH. | And the fact that a lot are none UK speeds Quote: | Is this something for a future release maybe? | Who knows, but a lot of work for Kremmen to do. |
Kremmen Pocket GPS Verifier
Posted: Sat Aug 05, 2017 5:52 am Post subject: |
Yes, it would be a big change as I currently only work with MPH.
It would probably be easier to copy the existing code and convert it into a 'EU CSV to GPX Converter'
A Winter project maybe. _________________ Satnav:
Car Average MPG :
Posted: Tue Aug 08, 2017 7:04 am Post subject: |
The latest zip package now contains both female and male voice packs.
Same link.
If you wish to change to male warnings then just unzip the package and copy/paste the .wav files over the female ones you currently have in the Working Folder. _________________ Satnav:
Car Average MPG :
Posted: Thu Oct 05, 2017 11:21 am Post subject: |
New version:
2017.10.05.65
This version adds 2 options when processing is complete:
Option 1 'Finish' - As now, just cleans up, saves your settings and leaves the Converter open for viewing statistics and/or changing the warning text.
Option 2 - 'Finish & Launch POILoader' Cleans up, saves settings, closes the Converter and auto launches Garmin's POILoader.
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0 _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri Oct 06, 2017 7:02 am Post subject: |
For those of us wishing to update is there a simple way, eg one file to copy, to do so or do we need to do a complete uninstall and reinstall? In the past that's what I've done but can I just replace an .exe file? _________________ Where there's a will ... there's a way. |
Posted: Fri Oct 06, 2017 7:08 am Post subject: |
Not tried just replacing the exe so I don't know the consequences.
Given that the exe is buried in your user area in that apps2 folder, twice, it's probably more hassle anyway.
I always do the full thing as it only takes minutes. _________________ Satnav:
Car Average MPG :
Posted: Fri Oct 06, 2017 7:14 am Post subject: |
Cheers, may be minutes for you as you're doing it more often than me, takes me a bit longer! _________________ Where there's a will ... there's a way. |
Posted: Fri Oct 06, 2017 7:30 am Post subject: |
Still minutes though, I didn't specify 2 or 99 _________________ Satnav:
Car Average MPG :
Posted: Fri Oct 06, 2017 7:32 am Post subject: |
Posted: Thu Nov 02, 2017 7:57 am Post subject: |
Voices addition.
I've noticed that CamerAlert has a different WAV for the RedSpeed cameras.
My current voicepack has a homebrew:
"RedSpeed camera xx miles per hour", created by me.
CamerAlert has:
"Redlight and speed camera xx miles per hour".
You now have a choice.
The default 'voicepack' still has "Redspeed" but there is now a new pack with the CA version, your choice:
Usual link _________________ Satnav:
Car Average MPG :
Posted: Wed Nov 15, 2017 12:06 pm Post subject: |
Purely Beta, to see how it goes.
I've put 3 help buttons in:
When you click the static button, it should open the .mht Helpfile at the exact position of the valid topic.
One snag I've found is that Internet Explorer doesn't close immediately every time so in most occasions it's a one off check. Then you may need to wait up to 20 secs for IE to close before another button will work.
[link removed- backed out]
Just 3 to start with as I'm not 100% convinced given the delay. _________________ Satnav:
Car Average MPG :
Posted: Wed Nov 15, 2017 8:09 pm Post subject: |
I expect peeps who use IE are used to all sorts of delays K so won't notice/worry about it.
I'll give it a whirl later. |
Posted: Thu Nov 16, 2017 5:29 am Post subject: |
Ta
If it gets a seal of approval I can extend it with more buttons if needed.
or
Strip it out as failed. _________________ Satnav:
Car Average MPG :
Posted: Thu Nov 16, 2017 9:18 pm Post subject: |
Doesn't open help file for me. Asks to find app in Store. So obviously I haven't got the right whatever to open .mhtml nor will any other W10 people by default. |
