bazzza Frequent Visitor
Joined: Nov 05, 2006 Posts: 260 Location: East Yorkshire
Posted: Thu Jul 20, 2017 8:30 pm Post subject: Go520 Image upside down |
Just got a GO520 which is taking a bit of getting used to. Not a simple as my Via 135. The big advantage of the Via was that it mounted in an absolutely perfect position with an Air Vent Mount.
The Go520 will also mount on the air vent but in its best position it is upsidedown. This wasn't a problem with the Via as the screen image always stayed right side up but this is not the case with the 520. Can the image on the 520 be turned over, or set to always orientate itself correctly? _________________ Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi |
dhn Frequent Visitor
Posted: Fri Jul 21, 2017 9:58 am Post subject: |
Are you referring to the 520 (WiFi) that comes with the magnetic mount? If so, the part of the mount that holds the device does rotate. It's stiff but a little shot of WD-40 loosens up the ball/
However, if you mean using the device without the mount, then I agree the screen does not seem to auto-rotate. At least, mine doesn't. _________________ David |
Posted: Fri Jul 21, 2017 1:42 pm Post subject: Go520 WiFi Upsidedown image |
dhn wrote: | However, if you mean using the device without the mount, then I agree the screen does not seem to auto-rotate. At least, mine doesn't. |
If it doesn't auto rotate or can't be rotated that's a pity. It means I can't mount it in the perfect position that my Via 135 does.
Cheers, Bazzza
Having thought about this: if it really is the case that the image can't be turned over, it is very disappointing that I have shelled out a lot of money for what I thought was an improved version of my old Go 520 which has gained some bells but lost some whistles. Having said that I am probably doing TomTom an injustice as I just checked my old Go520 and that doesn't turnover either. So I will probably revert to my Via 135.  _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
rwbaldwin Occasional Visitor
Posted: Fri Jul 21, 2017 8:44 pm Post subject: |
The function disappeared in v7 of the software. As far as TomTom is concerned, the menu option isn't required.
Mounts can be fitted in two orientations, keeping the TT the right way up. |
Posted: Fri Jul 21, 2017 9:00 pm Post subject: |
rwbaldwin wrote: | The function disappeared in v7 of the software. As far as TomTom is concerned, the menu option isn't required.
It may not be required by TT but it is by me.
Right way up, yes.
Right position, no.
I have just wasted a lot of money to get what is (to me) an inferior product to the Via 135.  _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Fri Jul 21, 2017 9:15 pm Post subject: Go520 WiFi Upsidedown image |
Right way up, yes.
Right position, no.
I have just wasted a lot of money to get what is (to me) an inferior product to the Via 135. [/quote]
Sorry Chaps, I seem to have been taking my disappointment out on you. Apologies.
Bazzza _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
M8TJT The Other Tired Old Man
Posted: Fri Jul 21, 2017 10:33 pm Post subject: |
Take it back as not fit for your purpose. None of the new TTs are 'as good' as the older ones. |
Posted: Fri Jul 21, 2017 10:48 pm Post subject: |
Bought it direct from TT. I don't fancy my chances of getting my money back. Looks like Ebay is my best bet _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Fri Jul 21, 2017 11:01 pm Post subject: |
What, return it to eBay when you bought it from TT? Sounds like a good plan, but possibly won;t work.  |
Rick-uk Lifetime Member
Joined: Apr 16, 2006 Posts: 330 Location: BS20, North Somerset
Posted: Sat Jul 22, 2017 7:04 am Post subject: |
If you bought it online then under the "Distance Selling Regulations" you have 14 days to return it, no questions asked, you don't even have to offer a reason. You may have to pay any postage costs though. _________________ https://share.octopus.energy/dense-raven-261 |
Posted: Sat Jul 22, 2017 9:33 am Post subject: Go520 WiFi Upsidedown image |
Rick-uk wrote: | If you bought it online then under the "Distance Selling Regulations" you have 14 days to return it, no questions asked, you don't even have to offer a reason. You may have to pay any postage costs though. |
Decided to return it and found that to be impossible. CS only work 5 days.
Instructions on how to return it tell you to send details but doesn't say where to.
Unless you send the details you can't get an RMA number (which is vital) or where to send it to. Clearly, TT don't want you to return things and make it as difficult as possible.
It's "Catch 22"
I go on holiday on Monday so that doesn't help. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Sat Jul 22, 2017 12:01 pm Post subject: |
Email them explaining what you want to do and why. Also explain that you'll be away. You should still then be able to return it when you're back.
You have to tell them within 14 days then have another 14 days to actually return it.
https://www.gov.uk/accepting-returns-and-giving-refunds _________________ Where there's a will ... there's a way. |
Posted: Sat Jul 22, 2017 12:21 pm Post subject: Go520 Image upside down |
sussamb wrote: | Email them explaining what you want to do and why. Also explain that you'll be away. You should still then be able to return it when you're back.
https://www.gov.uk/accepting-returns-and-giving-refunds |
I would be happy to email them if I had an address to send it to but I can't find one. I have a web Page that lists all the information you have to send them to get an RMA number but doesn't tell you where to send it.
I'm only away for a week so I should be ok to sort it on my return.
Thanks a lot
Iphone 6
TT Via 135M
GO520 WiFi |
Anita Pocket GPS Moderator
Posted: Sat Jul 22, 2017 1:09 pm Post subject: Re: Go520 Image upside down |
bazzza wrote: | I would be happy to email them if I had an address to send it to but I can't find one. |
You can send a message via this page of the website. There's no option for Returns but maybe use Orders and Shopping? At least you will have advised them that you want to cancel the order in good time and hopefully they will respond before you get back from your holiday. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Sat Jul 22, 2017 1:54 pm Post subject: Re: Go520 Image upside down |
Anita wrote: | bazzza wrote: | I would be happy to email them if I had an address to send it to but I can't find one. |
You can send a message via this page of the website. There's no option for Returns . |
Thanks Anita that was very helpful. There actually was an option for returns which made much more sense than the info I had before.
I have emailed all my details to them and explained that I am on holiday until 1/8.
Thanks again,
problem solved,
Iphone 6
TT Via 135M
GO520 WiFi |
