Pocket GPS World :: View topic - POI LOader problem
POI LOader problem
pcaouolte
PostPosted: Sun Apr 16, 2017 8:59 am    Post subject: POI LOader problem Reply with quote
I have a problem with POI Loader. It works correctly if there is a BMP file associated with the CSV file but when there is no BMP file present the first POI in the CSV file does not get included in the POI.GPI file.
For example if the csv file contains:
Code:
-2.92860,54.57143,"Aira Force",""
-2.96407,54.43416,"Ambleside",""
-3.13049,54.56661,"Ashness Bridge",""
Aira Force is only included in the POI.GPI file if there is a valid BMP file with a name that matches the CSV file.
Paul
PostPosted: Sun Apr 16, 2017 9:18 am    Post subject: Reply with quote
Not an answer, but a work around. Put a dummy in 'slot 1' so that when POILoader drops it, it doesn't matter. But I expect you have already thought of that work around.
But interesting stuff for Peeps who may not be aware of the 'problem'. Very Happy
PostPosted: Sun Apr 16, 2017 10:30 am    Post subject: Reply with quote
Or just create a BMP to match the CSV filename.
pcaouolte
PostPosted: Sun Apr 16, 2017 11:48 am    Post subject: Reply with quote
Yes, either of those two workarounds work but I was caught out with the missing POI when I didn't want to have a BMP showing on the map. It may help others to know of this issue.
The problem also occurs if the BMP is a size that POI loader doesn't like, for example a 16x16 BMP also causes the first POI in the CSV file to be missed and the BMP won't be displayed.
I don't always want matching BMPs for the POIs as I find that the map gets very cluttered when I have a lot of POIs and for some I only want to be able to navigate to them but I don't need to see their locations when passing them on the map.The Garmin displays an unobtrusive white flag for POIs without a matching BMP.
Paul
dales
PostPosted: Sun Apr 16, 2017 12:06 pm    Post subject: Reply with quote
To avoid map clutter, my .bmp's are simply 1 x 1 pixels.
Dales
PostPosted: Sun Apr 16, 2017 12:25 pm    Post subject: Reply with quote
And if you can crack the correct shade of purple, like my new camera iconc borders, they can be totally invisible.
PostPosted: Sun Apr 16, 2017 2:15 pm    Post subject: Reply with quote
A 1 x 1 invisible pixel eh! that should be quite difficult to spot, but would solve the 'missing poi' problem that shouldn't really be a problem in the first place.
Metblackrat
It's true magenta. 255,0,255 in the RGB settings.
PostPosted: Sun Apr 16, 2017 4:25 pm    Post subject: Reply with quote
Not quite as clear cut as that. It has to be the correct bit format as well, as I found out via Paintshop pro a month or so ago when a few failed.
pcaouolte
PostPosted: Sun Apr 16, 2017 6:43 pm    Post subject: Reply with quote
Unfortunately a 1 x 1 pixel BMP still causes POI loader to ignore the first item in the CSV file. A 24 x 24 completely invisible (all Magenta) BMP also causes the problem.
Paul
PostPosted: Sun Apr 16, 2017 7:09 pm    Post subject: Reply with quote
Then back to the 'dummy' POI it is then?
pcaouolte
PostPosted: Sun Apr 16, 2017 7:21 pm    Post subject: Reply with quote
Don't know. I'm beginning to think that I might be on the wrong track with this.
It definitely misses the first POI from some CSV files when compiling the GPI file.
In my initial tests it affected all the CSV files which didn't have a corresponding 24 x 24 bit BMP file but when I delete those BMPs it doesn't lose the first POI and if I add a correct BMP it doesn't restore the missing POI. I need to do more work on this. Sorry for the misleading information so far.
Paul
pcaouolte
PostPosted: Sun Apr 16, 2017 7:48 pm    Post subject: Reply with quote
Well, I was completely on the wrong track. Embarassed Sorry!
It turns out that the CSV files where the first item was ignored by POI loader had three hex bytes efbbbf as the first three bytes of the file. These bytes cannot be seen when opening the file in excel or notepad but are visible in a hex editor.
According to Wiki these bytes mark a Unicode byte order for the file. POI loader does not like these bytes and ignores the POI. It was just a coincidence that these files also had no BMP file or an odd size BMP file and that led me completely astray.
I have no idea what program adds these three bytes to a csv file. The solution is to use a hex editor to delete the three bytes.
Paul
PostPosted: Mon Apr 17, 2017 4:38 am    Post subject: Reply with quote
You're ringing bells. I've seen that before.
I think I just deleted and recreated the first line again in Excel, it was only 3 fields. Lat, Lon, Description.
It was a donated file so no idea what program added the bits.
Privateer
PostPosted: Mon Apr 17, 2017 10:32 am    Post subject: Reply with quote
Instead of using a hex editor, would using Notepad or Notepad++ to load and then save the .csv file work to strip those bytes?
Is there not a setting in Notepad or Notepad++ to save as UTF-8 encoding?
When I was trying to get POI .csv files right on a Mac, we eventually discovered that the .csv files had to be forced to use UTF-8 encoding. Especially for correct display of things like diacritical marks (accents).
Robert.
Garmin Camper 770 LMT-D
