Metblackrat Regular Visitor
Posted: Wed Mar 29, 2017 7:33 pm Post subject: 2018.10 Released. |
New maps are now available to download via Express. |
MichaelCahill Regular Visitor
Posted: Wed Mar 29, 2017 8:14 pm Post subject: Re: 2018.10 Released. |
Metblackrat wrote: | New maps are now available to download via Express. |
Before I download, can you confirm that there are no nasty surprises, like DEM maps disappearing, as happened previously? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Wed Mar 29, 2017 8:19 pm Post subject: |
Well unless the device has that map, mine doesn't, no one can. Just copy it to your PC first before you update just in case. _________________ Where there's a will ... there's a way. |
Dabri Lifetime Member
Posted: Wed Mar 29, 2017 8:43 pm Post subject: |
BEWARE. Just loaded new map onto my 3598 and it has frozen. It started up normally, but when I moved to the Navigation screen to switch on the GPS simulator it just stopped; will not respond to anything.
After holding the on/off button for a while (15 seconds or so) it started again. No maps appeared. Moved again to the GPS simulator and it has frozen again.
Another attempt. This time maps appeared. Disappointingly, a new ring road that opened in January is not on the map.
Never mind; all working again - probably. _________________ Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v7.70; Samsung A52. |
Posted: Wed Mar 29, 2017 8:57 pm Post subject: |
All mine updated without issue  _________________ Where there's a will ... there's a way. |
BAVC10 Lifetime Member
Posted: Thu Mar 30, 2017 11:38 am Post subject: |
Same here - all units updated without issue.
DriveLuxe 51 notified me via the built-in Wi-Fi that there was a mapupdate when I asked it to check for updates - but then had to connected to GE for the update! _________________ DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 494 Location: South Yorkshire
Posted: Thu Mar 30, 2017 4:35 pm Post subject: |
BAVC10 wrote: | Same here - all units updated without issue.
DriveLuxe 51 notified me via the built-in Wi-Fi that there was a mapupdate when I asked it to check for updates - but then had to connected to GE for the update! |
that's odd as you would expect it to update via wi-fi, otherwise what is the point of it |
Posted: Thu Mar 30, 2017 5:22 pm Post subject: |
I guess given it is nearly 8GB it is too large to do over the air - not that I'd want to take the risk anyway.
Wi-Fi seems fine for firmware and smaller (language/text) file updates although I've now disabled it as I keep getting 'nags' to find my home Wi-Fi when driving around - so it's a gimmick. _________________ DriveLuxe 51 LMT D - Firmware 6.80
Posted: Thu Mar 30, 2017 8:56 pm Post subject: |
my first attempt at updating the maps and stuck at downloading 26minutes for over 1 hour
had to disconnect unit and re-connect for it to do anything else (now finally copying the files over after it reported 3 hours to do) |
Kremmen Pocket GPS Verifier
Posted: Fri Mar 31, 2017 4:55 am Post subject: |
My map updates rarely go in first time. I nearly always have it freeze somewhere then have to stop and restart GE, then it works second go. Then my second unit works first time, maybe because the maps are already local.
That is on a 24Mbps fibre connection. But Garmin only seem to allow 3Mbps, even in the early hours before america wakes up, which is why it takes ages. I also don't allow the PC to sleep and all USB ports are not set to sleep either. _________________ DashCam:
Viofo A119 V3 |
toyracer69 Lifetime Member
Posted: Fri Mar 31, 2017 12:55 pm Post subject: |
Did mine last night, took a good hour to complete but it went in first time and worked this morning...  |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 564 Location: North Devon
Posted: Fri Mar 31, 2017 2:23 pm Post subject: |
Kremmen wrote: | That is on a 24Mbps fibre connection. But Garmin only seem to allow 3Mbps, even in the early hours before america wakes up, which is why it takes ages. |
That's odd. I updated the 3598 and noted with interest, that (for once) something was actually making half-decent use of my V.M. Cable connection.
(Microsoft Edge seems to consider this graph to be a security threat and doesn't seem to want to display it )
http://www.dropbox.com/s/frrrrqbzumov2wo/Garmin.png?dl=0 |
Posted: Fri Mar 31, 2017 3:18 pm Post subject: |
I'm on Virgin too and downloads appear to whiz through, but then I'm on 70Mbps  _________________ Where there's a will ... there's a way. |
Posted: Fri Mar 31, 2017 3:24 pm Post subject: |
For once both mine went in without a hitch.
According to the GE progress bar my download speed was only 8Mbps though. Took under an hour for the Europe and about 20 mins for the UK&I.
Wonder why it can't use the full 24Mbps that Speedtest identifies ? _________________ DashCam:
Viofo A119 V3 |
b33jay Lifetime Member
Posted: Fri Mar 31, 2017 5:18 pm Post subject: |
Why are the last two posts dated April 1st?
Edit: as I now see this one of mine is.
My PC clock is correct so.................... |
