Kremmen Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Thu Jan 05, 2017 3:33 pm Post subject: |
Nope that's not me
What with Basecamp and now this you're going through the wars _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Thu Jan 05, 2017 3:43 pm Post subject: |
Neither are real issues for a pro like me ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Where there's a will ... there's a way. |
Posted: Thu Jan 05, 2017 4:19 pm Post subject: |
Unless I'm mistaken you can no longer change map regions ?
On both devices all I get is the option to upgrade the maps 'on the device'
I wanted to switch the 2599 to UK & I _________________ Satnav:
Car Average MPG :
Posted: Thu Jan 05, 2017 4:41 pm Post subject: |
Yes if there's space you have no option but to accept the full map. You can fool Express though by placing other files there so that there isn't space for the full map, then you get to choose a region ![Wink](modules/Forums/images/smiles/icon_wink.gif) _________________ Where there's a will ... there's a way. |
Posted: Thu Jan 05, 2017 4:52 pm Post subject: |
OK, no problem.
I'll stick with the full Europe this time round. _________________ Satnav:
Car Average MPG :
Posted: Thu Jan 05, 2017 7:26 pm Post subject: |
This is now fixed. For those interested Garmin have now split the map into two, one part is placed by Express into the .system folder and the other into a folder named Map if there is sufficient room on the device. If not then the files are split on a sd card, between the Garmin and Map folder. _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 06, 2017 5:30 am Post subject: |
So if like me you don't want to use a SD card how does it decide which of the 2 maps you get, do you get a choice?
For us the best option is to have the region with the UK on the device.
Also, not that I want to change, my 2597 is now stuck on UK&I because that is the installed map set. _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 7:47 am Post subject: |
Yes, if you don't want to use a card you get a choice of what you do want to install to the device, just like before.
Unsure what you mean by 'stuck with the UK&I map'. If your 2597 came with a larger map set you can reinstall that if you want to? Or am I misunderstanding your comment? See this FAQ
https://support.garmin.com/faqSearch/en-US/faq/content/dyYgXK9i6C3FkS9sU5xDcA _________________ Where there's a will ... there's a way. |
BAVC10 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Fri Jan 06, 2017 9:59 am Post subject: |
Full Europe now shows (for me at least on a DriveLuxe 50) as 7.69 Gb rather than the 4.24 Gb it showed on GE yesterday - seems to have been fixed :-) _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
Posted: Fri Jan 06, 2017 10:11 am Post subject: |
I updated the 2597 yesterday and it gave me no option to change back to EU maps.
Possibly will do now I'm up to date.
Not fussed though, only need blighty _________________ Satnav:
Car Average MPG :
Posted: Fri Jan 06, 2017 10:50 am Post subject: |
Yes, you have to be up to date first, then you get the option to change regions ... _________________ Where there's a will ... there's a way. |
Posted: Fri Jan 06, 2017 3:22 pm Post subject: |
Interestingly, having installed to the hard drive on my PC as well, 2017.20 was 6.90 Gb whereas 2017.30 is only 4.87 Gb so I wonder if Garmin haven't quite fixed the issue yet. Even allowing for compression that's quite a file size reduction. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Posted: Fri Jan 06, 2017 3:46 pm Post subject: |
Not sure what you're seeing but the previous map was under 4GB ... the current one just over.
Certainly the map update issue is fixed, I've updated my device and verified everything using JaVaWa's Device Manager and Garmin's BaseCamp. _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Fri Jan 06, 2017 8:19 pm Post subject: |
OK I've got the new maps of All Europe, albeit now in two pieces.
But my new JCV file is half its previous size, so I must be missing, say, all of South Europe's Junction Views.
And my new SID and SQLITE files are also only half their previous sizes, so I've been shortchanged here as well, it seems.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Fri Jan 06, 2017 8:48 pm Post subject: |
You should have 2 jcv files ... One for each map _________________ Where there's a will ... there's a way. |
