Pocket GPS World :: View topic - screen freeze when speed alert activates on nuvi42
gray13
PostPosted: Thu Jun 23, 2016 8:21 am    Post subject: screen freeze when speed alert activates on nuvi42 Reply with quote
Hi , with pgps speed cam database loaded and active on my garmin nuvi 42, when I trigger the speeding alert on screen (red banner showing speed limit) for more than about 10 seconds the screen freezes at that road position . The only way to cure this is to reset the sat nav. i.e. switch off and on again. This does not happen when using the Garmin pre installed data base . Any ideas or has anyone else had this problem?
PostPosted: Thu Jun 23, 2016 10:19 am    Post subject: Reply with quote
Never seen that on any of my nuvis. Have you tried a master reset?
PostPosted: Thu Jun 23, 2016 10:45 am    Post subject: Reply with quote
New one on me as well, I'd like to see a screenshot including the problem red banner
Satnav:
Car Average MPG :
gray13
PostPosted: Thu Jun 23, 2016 1:13 pm    Post subject: Reply with quote
Ive just sorted out how to set up screenshot on the nuvi, is it easy to post a screenshot on here . As you may have guessed Im a bit of a dinosaur.
PostPosted: Thu Jun 23, 2016 1:30 pm    Post subject: Reply with quote
You need to get the file hosted somewhere (I use PhotoBucket) then post a link to the file on the forum.
You'll find the files in the Screenshot folder on your nuvi.
gray13
PostPosted: Thu Jun 23, 2016 3:38 pm    Post subject: Reply with quote
right think Ive got this figured out this should be the link to screenshots http://s1152.photobucket.com/user/graysteve13/library/
note speed and time of day
PostPosted: Thu Jun 23, 2016 3:43 pm    Post subject: Reply with quote
I haven't got a Nuvi42 but that red banner doesn't look like any PGPSW alert I've seen.
Satnav:
Car Average MPG :
PostPosted: Thu Jun 23, 2016 3:51 pm    Post subject: Reply with quote
That looks like the standard Garmin alert on those models.
gray13
PostPosted: Thu Jun 23, 2016 3:57 pm    Post subject: Reply with quote
The red banner is the speed alert warning , if I was below the limit it would normally be a black banner saying speed camera alert . But over speeding freezes the screen at that point as you can see from the time and the speed on the right hand bar . This does not happen when the garmin database is used .
PostPosted: Thu Jun 23, 2016 4:58 pm    Post subject: Reply with quote
Well as I said, that to me looks like the standard Garmin warning Wink
What makes you think it's the PGPSW alert?
gray13
PostPosted: Thu Jun 23, 2016 5:13 pm    Post subject: Reply with quote
Because Ive got garmin safety cameras off in proximity point alerts and the only custom pois loaded are the pgps ones.If I turn the pgps ones off and the garmin ones on I don't suffer from screen freeze. I see this type of banner whichever dataset I use .Does this make sense ?
