Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 26, 27, 28 ... 72, 73, 74  Next
PostPosted: Mon May 16, 2016 4:38 am    Post subject: Reply with quote
I should have time this week to add that as I'm coming to a pause shortly.
As you know I'm in Eastbourne for a few days from Saturday while the undercoat dries properly.
Just running round with a paintbrush today looking for missed bits.
I've got one job looking at the variable limit code that should be looking at the user set limit (in purple) on the main screen but apparently isn't.
I've got stuartb's voice pack to include into the install zip file.
I've now got this increased text.
Satnav:
Car Average MPG :
PostPosted: Mon May 16, 2016 7:58 am    Post subject: Reply with quote
New version 44:
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0
1) Warning message now includes prompt to unzip PGPSW file using the programs own unzip routine.
2) stuartb voice pack included.
3) Bug with user selectable variable speeds fixed. It was using the set speed to calculate the proximity but was replacing the 0mph test with 70mph.
(Note) The approach warning text does not include a speed because the camera is 'variable speed' but the overspeed element, if selected, now uses the user selected speed - good spot Very Happy
Satnav:
Car Average MPG :
Nemesis1
PostPosted: Mon May 16, 2016 4:09 pm    Post subject: Reply with quote
Cant access that link mate :-(
PostPosted: Mon May 16, 2016 4:17 pm    Post subject: Reply with quote
Link's broken K.
Error message is
"This site can’t be reached
dl.dropboxusercontent.com’s server DNS address could not be found."
PostPosted: Mon May 16, 2016 4:45 pm    Post subject: Reply with quote
Working for me?
PostPosted: Mon May 16, 2016 4:48 pm    Post subject: Reply with quote
Working for me too now.
Have spoken to Kremmen, he's done nothing so must have been a temp Dropbox glitch.
PostPosted: Mon May 16, 2016 5:06 pm    Post subject: Reply with quote
K, can you confirm it's v44? Having done a fresh install from the above link mine has 43 at the end?
PostPosted: Mon May 16, 2016 5:13 pm    Post subject: Reply with quote
Thanks for the headsup M8.
I'll check but the link was setup this morning. Give me 10 minutes...
Embarassed It is 43, what I did was look at the auto increment it does when you publish it.
The top version should show 2016.05.16.43
44 will be the next one which hopefully will be the % overspeed facility.
Anyway, the latest zip is dated today at 07:48
Dropbox must have had a fit because I've changed nothing since this morning.
Satnav:
Car Average MPG :
Nemesis1
PostPosted: Mon May 16, 2016 6:29 pm    Post subject: Reply with quote
Got it.
Also been an interesting update regards the system used in the Merc.
Will update that thread.
PostPosted: Mon May 16, 2016 6:59 pm    Post subject: Reply with quote
Thanks nemesis.
There was a major overhaul a month or so back due to the directional voice alerts. After that overhaul it was given some serious testing and a few other bugs were detected and ironed out.
I did check your warning message area and it seemed to still be working OK.
The detected bugs didn't affect any missing camera data or anything fundamental, that was OK, it was mainly cosmetic like camera counts and going the wrong way and including some cameras you asked it to ignore.
Satnav:
Car Average MPG :
Nemesis1
PostPosted: Mon May 16, 2016 8:16 pm    Post subject: Reply with quote
Looks good to me mate.
Can't use custom sound files in the Merc so no probs there for me.
PostPosted: Tue May 17, 2016 4:48 am    Post subject: Reply with quote
Ta Smile
Satnav:
Car Average MPG :
PostPosted: Wed May 18, 2016 11:18 am    Post subject: Reply with quote
OverSpeed enhancement:
Here's how I see it:
The theory is that the warning speeds will be controlled by the up/down arrows.
They will be limited to the speed limit and the 10% +2.
The 50 one will therefore only range from 50 to 57. That will stop any mistakes.
This is just a screen mockup, there is no code behind it yet.
If you change the speed over the limit the that overspeed colour will change from green to red.
Also, the VAR speed will be lifted from what you have set for the Gatso VAR on the main page.
The above are all just thoughts/suggestions waiting for feedback before I start coding.
Satnav:
Car Average MPG :
Allan_whoops
PostPosted: Thu May 19, 2016 8:33 am    Post subject: Reply with quote
Looks good.
Are you going to give the option of splitting out the cameras eg mobiles, fixed and specs or is that far more time consuming?
PostPosted: Thu May 19, 2016 12:13 pm    Post subject: Reply with quote
I've just finished a beta version 2016.05.19.44
https://www.dropbox.com/s/3q8pmzybhoybzxc/CSV%20to%20GPX%20Installer.zip?dl=0
This link is different to the normal version 43 so it's not forced on everyone.
I've updated the manual with what you need to do, not much.
Let me know.
This is just separated by speed as I didn't consider trying to separate it out by camera type as well. Not impossible but I'd rather wait until this version has been tested and OK'd so any issues are less to change.
PS: I've also had issues with DropBox not always connecting first time so keep trying to download if it first fails.
Satnav:
Car Average MPG :
Page 27 of 74
